Delete please
Discussion in 'The Garage' started by Hossbaby50, Jul 31, 2004.
  1. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I am about to replace the ignition switch in my truck and I forgot to read the manual about it when I was at the parts store.
    I have the steering wheel puller already and the ignition switch. What is the process for replacing the switch. I am about ot do this so ASAP.
    Harley
  2. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Re: Ignition Switch Replacment?\'s ASAP
    The ignition switch sits on top of the column behind the bolts that hold the column up on the dash. It's about a 10 minute job.
    If you're talking about the lock cylinder it's a little more involved. Pull the steering wheel, turn signal switch, some other stuff, and then there is a little pin that holds the lock cylinder in. If you stare at it long enough you'll figure it out. The most difficult part is not ruining the turn signal switch or losing the itsy bitsy contacts.
  3. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Re: Ignition Switch Problems?\'s ASAP
    Problems
    My lock cylinder isn't bad like I thought but I think it is the piece the cylinder goes into.
    When I turn the key on it won't give the ignition power and it doesn't do anything. No dash gauges, no fuel pump, no starter, etc
    Harley
  4. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    I take it that the rod that the cylinder moves to go down to the ignition switch doesn't move?
    If you have tilt steering there is a piece of cast pot metal that sometimes breaks. If that's the case... put in a different column. I had this experience a long time ago. I think the post would've been made when I was "wrathORC" though.
  5. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    I had this problem once too and after I had replaced the ignition switch and a few other things I bagan to check the power source. Yurned out that the wires on the starter were shot so I replaced them and wham, it fired right up.
    Truck had started fine all day and then it just didn't want to go anymore. Good Luck /forums/images/graemlins/waytogo.gif
