Delete Please
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 78 k5, May 26, 2005.
  1. 78 k5
    78 k5 1/2 ton status
    Jul 8, 2004
    261
    Auburn, AL or ATL, Ga
    delete
  2. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    It is one of the lowest stock ratio cases you can get, strong internally, weak externally cuz of the al cases.
    Make sure that the cones are tight - if it is leaking there from loose bolts you can mess up the cases and never get them to seal right.
  3. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    Keep it full of ATF and it will more than likely last for many years to come. The 241's usually die from lack of lube or rocks - seldom from too much power.
    Tom
  4. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    X2
    Mine NEVER gave me a lick of problem, and it ran the last part of it's life clocked up flat. Keep it full of fluid, shift it into 4wd every now and then, and it will stay happy. If you plan on wheelin with it, clock it up and build some protection around it. the aluminum is SOFT and WILL CRACK if you aren't careful.
    KP
