Delete Please
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 78 k5, Jun 8, 2005.
  1. 78 k5
    78 k5 1/2 ton status
    Jul 8, 2004
    261
    Auburn, AL or ATL, Ga
    delete
  2. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    You actually shouldnt physically be able to fill the t case until its over the fill hole to where it would come out if you opened. There is a seal between the tranny and tcase that, if leaking, leaks tranny fluid from your tranny into your t-case. Just make sure the tranny is full of fluid.
    -Harrison
  3. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    As was already said, the input shaft seal of the T-case is probably bad and allowing tranny fluid to enter the T-case. The seal is very easy to change and also real cheap. The T-case is pretty easy to remove as well so i would say remove the T-case and buy a new seal and fix it correctly and then refill the T-case to the bottom of the fill hole.
  4. 78 k5
    Jul 8, 2004
    261
    Thanks for the help, will the overfilling hurt the t-case?
