***DELETE***
Discussion in 'The Garage' started by boz42, Mar 19, 2004.
  1. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    i have hunted on the net tonight & haven't been able to find any info on this. i want to put one of these behind a BBC chevy that makes around 475hp & 550ft/lbs. it also has a 150 shot of gas. the propose vehicle is a 69 chevy truck i have a couple of questions?
    1. who makes a stand alone computer for (how much $$) these
    2. who makes a speedo conversion to drive a factory speedo?
    3. does any one make a stall converter i will need one around the 2500rpm range?
    are the conversion parts affordable?
    thanks for any help or advice. /forums/images/graemlins/thumb.gif
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    Re: 4l80e in a non-computer controlled truck
    1. JET
    2. Dont Know
    3. TCI
  3. dyeager535
    26,980
    Last I recall, the standalone setup for the 4L80E was upwards of $500.
    jagsthatrun.com has various speedometer/VSS drivers that might be what you are looking for.
  4. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    TCI,Compushift,there are a couple of others also. You can also use a 91-93 chevy diesel truck computer that came with a 4l80e.
    There are a couple of manufactures that make a gizmo to take a VSS signal and run a mechanical speedo - if thats what you are asking.
    Several companies - Jet is one and there is a place in Phoenix - Performance Transmission I think.
    Subjective question. Yes if you want or need to run a 4l80e - and you can afford it. No otherwise. I have bought TCI controllers for $400. A new Compushift is around $950. Plus you need VSS input, RPM input and TPS input.
  5. jwduke
    jwduke 1/2 ton status
    Aug 25, 2001
    721
    Ice Cream Capital of the World, IA.
    I'm not trying to hijack this post (sorry), but I went to jagsthatrun.com, and they say ALL TBI engines use VSS, I don't think so....... My '87 doesn't, or does it?? Again sorry, and now back to your regularly scheduled post!
  6. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    your TBI has a VSS, but it is on the back of the cluster, driven by the speedo cable
  7. jwduke
    Aug 25, 2001
    721
    Since I added 4.56 gears & '35's, can I get by changing the gear at the transmission to get things correct?
  8. dyeager535
    26,980
    Yep. Electric Speedo's are the only ones that didn't use gears to drive the speedometer/VSS.
