delete
Discussion in 'The Garage' started by boz42, Aug 19, 2004.
  1. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    delete
  2. jwduke
    jwduke 1/2 ton status
    Aug 25, 2001
    721
    Ice Cream Capital of the World, IA.
    Re: manuel line lock?
    Why would you want a manual one??
  3. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    here ya go these are the sh!t. they selling for about $190 over at awdirect.com the one you might want is mico part# 02-640-125.
    mico.com
    and the reason you would want an manuel linelock is bacause ther is no current draw when engaged and that can bcome an issue over extended periods of time. Also a mojority of electriclock are not ment to be used but for minutes at a time.
  4. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Mico's line of electric locks only use power to engage them. The differential in line pressure holds them closed. Stepping on the brake pedal disengages them.
    The "Line Locks" from Summit etc need power all the time to hold them closed and they are not intended for long term use.
  5. wasted wages
    wasted wages 3/4 ton status
    Dec 3, 2003
    9,194
    Dallas Texas
    I have had a mico lock on the k5 for two years (manual)
    They all leak down over time and are not meant to be a replacement for e- brakes. Flip the lever,, pump the brake hard and it holds for about 12 hours,,,,
  6. ntsqd
    Nov 28, 2002
    3,381
    So. CA
    BTW, Jamar sells a product similar to the manual Mico Lock called a "Park-Lock". Look in a Hot VW's mag as they are mostly sold the sand rail crowd.
  7. boz42
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    thanks for the info
