delete
Discussion in 'The Garage' started by R72K5, Apr 29, 2005.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    jhgc
  2. kgblazerfive
    kgblazerfive keymaster Premium Member GMOTM Winner
    Dec 2, 2004
    10,614
    602
    Hooper, Utah 84315
    Keep them and use them on the engine that they are on. Do a serch on E-bay they are nice heads but unless you or someone else is looking to build something that came with them stock they are not worth much. In trying to find a set of heads for my super stock (still looking) you can get a set of camel hump fulie's for around three hundred or so. Or you can get a rebuilt and redone set of 202's heads for around $400. If someone is going to build a race moter alluminum is cheap enough now to just get them, or a set of vortec's.
  3. primergray4x4
    primergray4x4 Registered Member
    Mar 22, 2004
    44
    Peyton, Co
    487x heads
    I had a set on my 350 I had built by a dirt track racer. I loved them, very strong. If you don't want them I'd be very happy to help you get rid of them :cool1:
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i may sell them i dunno, id like to find a set of 80-up 4416 305 heads for this 305 engine, and some kind of regular 350 heads- nothing special, but yet decent and not crack prone, such as 993's or similar- for the CMJ 350 in the 84 truck..
    hum..
    i dunno.,.
    anyone know anything?
    can help somehow maybe ?
    im almost tired of trying to get heads i want on these two engines- that need to be on them for what they are...
    what a pain..
    thanks
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
  7. primergray4x4
    Mar 22, 2004
    44
    Peyton, Co
    487x heads
    Right now I have a set of stock 88 350 heads, they used the same valves but don't produce the same bottom end power that the 487x heads did. I've had to put the stock springs back on the HEI dist. My motor was built so that everything was matched. I just knochted the center two bolt hole on the intake to allow for the differnt bolt pattern in the middle. Please keep me in mind if you want to sell them. I believe they came off the 70-72 327 vett's. Best of luck with your quest on finding the right set that you want. :laugh:
  8. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    where are you located ?
    what you doing with the 88 heads? have any later 305 heads ?
    so far i have planned to use the 487x on the cmj 350 in the 84, even though they are alot of head for stock anyways, but i have nothing else to put on and still need to find a set of 305 heads for the 305 in the 71,,
    so i dunno
    cant find crap cept hi perf 350/400 heads.,,. i just want good stock normal stuff, but its like impossible,,.
