Delete
Discussion in 'The Garage' started by Leper, May 7, 2006.
  1. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    DELETE, he limped it back.
  2. koldsimer
    koldsimer 1/2 ton status GMOTM Winner
    Jan 10, 2005
    1,480
    texas
    Any add on mods that could be malfunctioning? No help, I know. Good luck to your bud, at least he has a friend like you to help him out.
  3. Leper
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    IT's BUBBA!!!!!
  4. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    Smoking out the exhaust; white or black smoke? At idle? Under load or acceleration? At a steady cruise?
  5. Leper
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Exhaust White smoke, (load ,accelleration and cruise, I believe.)
  6. koldsimer
    Jan 10, 2005
    1,480
    texas
    Damn... lemme know how I can help.
  7. koldsimer
    Jan 10, 2005
    1,480
    texas
    white smoke isn't usually good for the diesels is it?
  8. Leper
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    I know I've heard of this, I just can't remember the fix. I'm thinking it is simple.
  9. koldsimer
    Jan 10, 2005
    1,480
    texas
    Injector problem maybe... should be black smoke though, right?
  10. 1985_K5_Silverado
    Dec 21, 2005
    984
    Corn Country
    It's possible that the combustion temp is too low. Does the exhaust have an unusually strong diesel fuel odor? It might also be a bad injector.
    Is the cooling system level dropping at all? A head gasket leak can do the white smoke thing (steam, of course, but it looks a lot like white smoke).
  11. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    white smoke is oil isnt it
  12. koldsimer
    Jan 10, 2005
    1,480
    texas
    Hell, it bubba can't figure it out, I don't know why i'm trying to help.
  13. Leper
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Coolant level is fine. The truck was on the road for over an hour when it started, so I think the temp is ok.
  14. 1985_K5_Silverado
    Dec 21, 2005
    984
    Corn Country
    Has he got an exhaust temp gauge on that thing? I'm just curious if it reads differently (as in lower) than normal.
  15. icedragon
    icedragon Registered Member
    Sep 6, 2005
    18
    connecticut
  16. Leper
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    thanks.
  17. Leper
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    He was having to floor it to get it to go 40 mph. He stopped and checked everything again, and when he took off, the problem went away for a while again and is back again. Does anyone know anyone into the Dodge diesels they can call for a educated guess. He is several hours away from home right now, limping his truck back to Dallas.
  18. icedragon
    Sep 6, 2005
    18
    connecticut
    found tgis to
    did he get his last fuel from same place as usual?
    1. My truck is smoking white/blue smoke:
    A: Valve and injector adjustments are not correct. Also verify the accessory drive gear alignments are correct prior to setting the overhead.
    B: Bad injector or injectors.
    C: Camshaft injector lobe or lobes flaking.
    D: Incorrect injection timing.
    E: Worn rocker boxes, injector links or push rods.
    F: Bad fuel.
    G: Water temperature not holding at proper operating temperature.
    H: STC/MVT system malfunctioning or lube system sucking air (STC
  19. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I bet the turbo is dieing.
  20. Leper
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    He filled the 100 gallon extra tank before he started the trip. Same place as always. Thanks for the info. As of right now, the truck is running correctly. I am leaning towards an injector problem. I will update in a little while.
