Delete
Discussion in 'Parts & Trucks Wanted' started by Metrodps, Jan 17, 2007.
  1. Metrodps
    Metrodps Strange but nice guy Premium Member GMOTM Winner Author
    Jan 4, 2006
    9,727
    109
    earth
    Scored a complete SCI dealer/OEM add on can't tell it from factory parts. Plug a go.
  2. only 31s
    only 31s 1/2 ton status
    Oct 5, 2004
    224
    mass
    what parts?
    do you need underhood or the column stuff?i have a 90 jimmy with the parts.i wont charge you much for uunder hood -but to dissasemble the steering column is out !how bout 40+shipping for anything cruise related under the hood?
  3. Metrodps
    Jan 4, 2006
    9,727
    109
    earth
    I will scan the areas, I do not need the trun signal arm part. I will post it saturday. But sounds like we may have a deal!
  4. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    You might also want him to grab the wiring that comes thru the firewall into the interior that plugs into the column (its easy to get out). Then all you would have left is to buy a steering column with the cruise switches already on it.
  5. Metrodps
    Jan 4, 2006
    9,727
    109
    earth
    Yes I need the wiring but might have everything I need from jekquistk5. I will know on the third. I did the tilt allready and it had the cruise switch.
  6. Metrodps
    Jan 4, 2006
    9,727
    109
    earth
    OK I need the wiring for the cruise these pics show what I need plus the switch and bracket that goes over the brake pedal.
    Control unit.
    The servo unit
  7. kennyw
    Jun 9, 2002
    13,224
    94
    I have a complete cruise control wiring harness off of a 1985 Suburban 6.2L diesel truck. Some of it will work for you, at least the in cab section of the harness is the same. Under the hood it will probably be the same harness but the diesel harness is longer. I even have the little brain box and pedal mounted switch and maybe still have the bracket for the switch.
    How does $40 shipped sound?
  8. Metrodps
    Jan 4, 2006
    9,727
    109
    earth
    :deal: See what you have and PM me
  9. kennyw
    Jun 9, 2002
    13,224
    94
    I'll have to dig it out tomorrow night and get you some pics. Time for bed for tonight.
  10. kennyw
    Jun 9, 2002
    13,224
    94
    I haven't completely forgot about this yet... just been short on time. I'll try to get it this weekend.
  11. kennyw
    Jun 9, 2002
    13,224
    94
    Here are some pics of what I have...
    Engine end.
    Grommet thru firewall looks worse in pic for some reason. Wires are not frayed just the plastic tape.
    Electrical connections near the bottom of the column (red wire provides power from the fuse panel, black wire clips on ground terminal under dash).
    Vacuum switch, control box, etc.
  12. Metrodps
    Jan 4, 2006
    9,727
    109
    earth
    Got a new SCI Dealer add on unit. $105.00
    [​IMG][​IMG]
