Deleting my tranny dip stick...
Discussion in 'The Garage' started by supersize75k5, Aug 5, 2006.
  1. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    I am thinking more and more about ditching this thing on my buggy:screwy:
    Last weekend went out to play and my friend rolled his buggy here in florance and about 2 seconds later I got to start screaming as the burning sensation of tranny fluid was on the lower half of my body, I was so irrational by the ordeal I tripped trying to get out and thus put a bruise on my knee that hurt even worse..:1zhelp:
    so with my buggy Im thinking about ditching it all together, my thinking is that since it wont see to many miles, I could simply make a dip stick to stick only when I wanted to check it and just have a newer style dipstick tube handle for my plug that locks, or maybe some type of pressure insert or just a plug? any ideas?
    or even having it bored out and threaded when the case it apart for rebuild and put a plug similar to a radiator drain?:confused:
    I have found that even the locking dipstick tubes leak at times in a roll..
    just thinking, other then checking fluid level it performs no other funtion I can think of?? venting it done soly by the vent sooooo?
    situations like this guys suck..
  2. DavidB
    DavidB 1/2 ton status
    Oct 8, 2001
    2,617
    El Centro, CA
    Um...how did he do that???
  3. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    what about something like this?
  4. supersize75k5
    Feb 3, 2004
    8,832
    4
    gilbert az
    cant view.. the pic, have a link? damn I need to find my debit card:thinking:
  5. supersize75k5
    Feb 3, 2004
    8,832
    4
    gilbert az
    I dunno..ran out of skill...??
  6. Chaddy
    May 23, 2005
    4,110
    Salt Lake City,Utah
  7. supersize75k5
    Feb 3, 2004
    8,832
    4
    gilbert az
    HMM
    wondering if the fact that it is flexable, makes it less likely to leak from the trans case where the grommet is.
    that ones does not look as if the dip stick has a way of locking shut though like the 90's gm ones do.
  8. Chaddy
    May 23, 2005
    4,110
    Salt Lake City,Utah
    I know a few guys running that set-up in there rock buggy's and have never had a problem.
  9. DavidB
    Oct 8, 2001
    2,617
    El Centro, CA
    Seems like a guy could rig up some sort of flex setup with hyd hose and some caps or something.
  10. supersize75k5
    Feb 3, 2004
    8,832
    4
    gilbert az
    good to know, seems I may add some bling then when I get to that step:waytogo:
  11. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Pick up phone , dial bank , open mouth , wait 2 or 3 days , open mailbox , remove debit card . Damn man , you mentioned needing one days ( yes days as in plural ) ago :rolleyes:
  12. thatK30guy
    Jan 12, 2001
    32,076
    55
    Get a factory locking type dipstick.
  13. K5Chris
    K5Chris 1/2 ton status
    Mar 11, 2002
    805
    New Orleans, LA
    only thing i hate about those lokar flexible dipsticks, is the diameter of the tube is TINY. i didn't have a funnel small enough to fit in it, and it takes FOREVER to fill 12 quarts of atf through a tiny hole like that, especially when you have to make a funnel out of cardboard.
  14. muddermilitia
    muddermilitia ThatTrazerGuy GMOTM Winner
    Nov 10, 2005
    5,742
    76
    NE Illinois
    That is so true!!! My brother has the lokar dipstick on his M-37 and it takes so long to add fluid
  15. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Does your engine dipstick leak too?
    What I did w/ Patch's engine 'stick (for a different reason) was to braze the stick to the tube. Then I cut it with a tubing cutter and inserted a compression union fitting. Tightened up both ends and then backed off the top tube nut to just be hand tight. Now it doesn't leak dirt in or oil out and it's still easy to check the level.
    For a trans tube I wouldn't use the compression fitting (assuming you could find one that large), I'd use an AN union fitting and tube nuts w/ sleaves. Could go with JIC if you want steel instead of aluminum fittings.
    Would be a little trickier not disrupting the fluid level reading b/c the union fitting will extend the tube a bit. So you'll need to make two cuts.
  16. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    With the lokar dipstick it is a pain in the ass to fill, it drains in very slowly. But mine came with a little "adapter" that goes on top if the stick and allows the use of a normal size funnel.
  17. supersize75k5
    Feb 3, 2004
    8,832
    4
    gilbert az
    thats a neat idea!
    hell some cars though, such as jetta's and passats do not even have a dip stick for the tranny any more, with my luck the tranny will break long before I ever need to change the fluid and filter lol
    maybe a mini dipstick like marve had..just a dip stick cut down to five inches and a factory red locking dip stick cut down to size,
    thanks for the ideas,
    the lokar does sound like a pain but you dont have to fill a tranny that often
  18. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Personally I'd consider tapping the hole and puting in a plug and just fill as needed.
    Could be worse, newer Exploders are a PAIN to fill.... The only way to check the fluid level is to remove the drain plug on the pan, install a tool(quickly) then see if the fluid comes out of the tube. If it overflows through the tube, its overfull, if it doesn't, fill it until it does come out of the hole(like a diff filling). Got to love Ford.
  19. Chaddy
    May 23, 2005
    4,110
    Salt Lake City,Utah
    Thats what I was gonna say, and whats an extra couple minutes every couple years:wink1: I will be running 1 shortly:D
  20. onetonbb74
    onetonbb74 1/2 ton status
    Dec 1, 2005
    2,083
    Campbell, CA
    ive had a cork in mine but you need to fill it with a fill tube first g/l
