Dent Fix - Help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by beefcake83, May 21, 2001.
  1. beefcake83
    beefcake83 1/2 ton status
    Jun 24, 2000
    240
    Alaska
    Hi all - I have a little dent on my right front fender just behind the headlight that is bugging me. I'd like to punch it back out, but it's in a tight spot. GM in their infinate wisdom, spot-welded the front fenders on instead of using all bolts. It's not creased, but is about 1/2 - 3/4 of an inch in and fist size. Any ideas? - Gary
    Gary Graham
    '83 GMC Jimmy 350 'Beefcake'
    Eielson AFB, Alaska
    Metallica & Mountain Dew
    http://community.webshots.com/user/beefcake83
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    try a suction cup (sold at most auto parts stores) or a plunger w/ soapy water.
    '71 Blazer CST with alot of rust
  3. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    If you have never done body work it may end up looking worse. Fenders are bolted on not welded. So if it is spot welded someone else did it not G.M.
  4. BillyBob
    BillyBob 1/2 ton status
    Feb 23, 2000
    557
    Dumont, NJ
    Dents give character! I remember when I waffled my passangers side fender on a tree. boy did it look bad at first, but now, I don't even give it a second glance. I love all my dents and rot holes. With out them, people wouldn't get out of my way on the highway![​IMG] Anyway, I wouldn't mess with trying to pull a dent. You may end up making it look even worse.
    <A target="_blank" HREF=http://billybob.coloradok5.com>http://billybob.coloradok5.com</A>
  5. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    where hes talkin about(i think)is a spot where the inner and outer fender is welded together.as advice earlier said id leave it alone.that is kind of a tough spot to mess with.and you could end up making it look worse.if your planning to go ahead and do all the bodywork go for it.otherwise id leave it for now.
    PURE INSANITY
    86 blazer see it at:<A target="_blank" HREF=http://www.zing.com/album/pictures.html?id=4292792569>http://www.zing.com/album/pictures.html?id=4292792569</A>
  6. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    1.Bondo
    2.trowel
    3.sand
    4.Krylon :)
    All work and no beer makes Frizz a dull boy
  7. beefcake83
    Jun 24, 2000
    240
    Alaska
    Really.... Maybe I need to take a closer look, but when i only the hood, I don't see bolts along the top of the fender where it meets the engine bay like on most vehicles. Instead the metal is sort of pinched together every foot or so... not the type of welds that you or I would make with extra metal added. Can you tell me where the bolts are found, if indeed they are just bolted on. Thanks
    Gary Graham
    Eielson AFB, Alaska
