Denver area salvage yards
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by scott87, Jan 1, 2002.
  1. scott87
    scott87 Registered Member
    Feb 7, 2001
    39
    basalt, colorado
    Could anyone suggest some good salvage yards to check out in the Denver area? I'm starting a hunt for a rear axle for my 87 K5.
  2. 79ChevySB
    79ChevySB 1/2 ton status
    Jul 8, 2001
    178
    Denver CO
    Check Peoria and 33rd right off of I-70. I cant remember the yards name, but it is down on 33rd. What are you looking for?
  3. scott87
    Feb 7, 2001
    39
    basalt, colorado
    I'm starting to look for a 12 bolt, 3.73 ratio, mid 70's issue. Not set on that for sure (a FF14 bolt would be nice, probably too much axle for me right now), but that's where I'm starting out.
  4. i_4x4
    i_4x4 1/2 ton status
    Feb 20, 2000
    359
    Brighton, Colorado. USA
    That yard is called Pull n Save. I frequent it often it's about 5 blocks away from my work. They have weekend specials, sometimes rear ends for $20 plus a $10 core. Pretty cheap. Normally they are $80 any other time. The Chevy section gets rotated out about every 3 weeks.
    Later Ed
    Get use to the view.
    Because, if your not the LEAD DOG the view never changes.
  5. Donovan
    Donovan 1/2 ton status
    524
    Arvada, CO
    My buddy just pulled one out of his blazer. That is a 12 bolt with 3.73. Let me know and I can get in touch with him. He live in Arvada.
    Donovan
    <a target="_blank" href=http://www.rustbucket.rockcrawler.com>www.rustbucket.rockcrawler.com</a>
    Got Leafs??
  6. i_4x4
    Feb 20, 2000
    359
    I also have a 10 bolt front w/ 3.73's out of my '85. $25 it's yours. I need the room in the garage. The wife seems to think she needs to park in thier because it's winter or something like that.
    Later ED
  7. 79ChevySB
    Jul 8, 2001
    178
    Denver CO
    Yeah Pull N Save, thanks man. Do you know if the spring perch width changed when they went to the newer 88-up trucks from the older 73-87 trucks? Like if I wanted to swap in a 14FF into my 92 Blazer. Thanks.
    Hey this is FUN!
  8. iceman
    iceman 1/2 ton status
    Oct 26, 2000
    208
    Littleton, CO. 80127
    Yes, they did move the spring perches and shock mounts in 88 I have a friends 10 bolt out of a 94 and it fits nothing I have go figure. Are you doing a complete re-work of your rig? I believe the frames are wider in the later years as well. Iceman
