Desk top dyno help please
Discussion in 'The Garage' started by Chevy305, Aug 29, 2006.
  1. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,228
    485
    New Hampshire
    Could you guys with the desk top dyno make 2 runs with different cams for me on my 305? Please...
    Specs:
    1983 305 L69
    stock bottom end (flat top pistons)
    Intake: Weiand Action+
    duel plane aluminum intake manifold
    Carb: Holley 600cfm #4160
    Distributor: Proform Race HEI
    50,000 volt coil
    Heads: Trick Flow 175cc 23*
    Intake Runner Volume (cc):175ccExhaust Runner Volume (cc):67cc
    Intake Valve: 1.94
    Exhaust Valve: 1.50
    Cumbustion Chamber: 56cc
    http://store.summitracing.com/partdetail.asp?autofilter=1&part=TFS%2D30300002&N=700+4294925232+4294838998+4294867081+400098+4294867028+4294784286+115&autoview=sku
    Cam #1: Lunati Voodoo Cam 268*
    hydrolic flat tappet
    Intake Duration at 050 inch Lift:227Exhaust Duration at 050 inch Lift:233
    Intake Valve Lift with Factory Rocker Arm Ratio:0.489 in.Exhaust Valve Lift with Factory Rocker Arm Ratio:0.504 in.
    Lobe Separation (degrees):110
    http://store.summitracing.com/partdetail.asp?part=LUN%2D60103LK&N=700+4294925232+4294924497+4294861490+400421+4294908216+4294840138+4294925044+4294887485+115&autoview=sku
    Cam #2: Lunati Voodoo Cam 262*
    Intake Duration at 050 inch Lift:219Exhaust Duration at 050 inch Lift:227
    Intake Valve Lift with Factory Rocker Arm Ratio:0.468 in.Exhaust Valve Lift with Factory Rocker Arm Ratio:0.489 in.
    Lobe Separation (degrees):112
    http://store.summitracing.com/partdetail.asp?part=LUN%2D60102LK&N=700+4294925232+4294924497+4294861490+400421+4294908216+4294840138+4294925044+4294887485+115&autoview=sku
    If I left anything out that you need to know let me know.
  2. Chevy305
    Jan 23, 2006
    11,228
    485
    New Hampshire
  3. yoshisv
    yoshisv 1/2 ton status
    Feb 19, 2006
    266
    Hartsville, Tennessee
    pm'd ya
  4. Chevy305
    Jan 23, 2006
    11,228
    485
    New Hampshire
    Anyone think the carb or intake is holding the power back?
  5. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,992
    130
    No way.
  6. Chevy305
    Jan 23, 2006
    11,228
    485
    New Hampshire
    Ok according to yoshisv for power with this setup on the 268* cam I get
    355hp @ 6000rpm
    350 lbs @ 4500rpm
    A bit of a higher winder but not bad for a 305 with a bone stock short block.
  7. beastofablaze
    beastofablaze 1/2 ton status
    Apr 4, 2005
    441
    CA
    did you enter the flow numbers on the heads? if not its about pointless...
