Desktop dyno and big block 454 heads.....
Discussion in 'The Garage' started by Zeus33rd, Mar 30, 2006.
  1. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    So I'm playin with Desktop Dyno,and have pretty much everythign figured out and dialed in except for the heads. My motor has the "peanut port" heads. Oval port. I don't know which of the availble selctions most closely match my heads. Here's apicture of the avaialbe choices-
    My best guess was the Canted/Oval Stock ports, Stock Valves. Am I way off base? It seems to make good torque numbers....Nice and flat from under 2k rpms to 4500.
    Anyways....Who's got a clue? I sure don't..:crazy:
  2. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,992
    130
    Do you know the casting #'s of your heads? The only way you will get any kind of accurate estimate is to use the custom port flow option. Search google for flow numbers for your heads and enter them into there (Desktop Dyno probably has your heads already in its database).
  3. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Yeah, I know the casting number-
    14092360...86-90...oval...OPEN...454 Truck, "peanut" round ports
    2.06 intake, 1.72 exhaust
    What exactly would I Google for? :crazy:
  4. beastofablaze
    beastofablaze 1/2 ton status
    Apr 4, 2005
    441
    CA
    yup... everyone that bitches about the desktop dyno being way off needs to use the custom port flow feature.
  5. wicked jester
    wicked jester 1/2 ton status
    Jan 8, 2004
    139
    CANADA
    These should get you close.
  6. 1977k5
    May 26, 2003
    9,992
    130
    ^^^ Those aren't the same heads. I couldn't find flow numbers for the 14092360 heads but what wicked jester posted is what you are looking for.
  7. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Right on!
    Thanks. :)
  8. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Ok, entered the numbers wicked jester posted and made a small cam change-
    Definatley not a screaming mud or street type motor, but a good for a daily driver I think. :D
  9. beastofablaze
    Apr 4, 2005
    441
    CA
    yeah... only 470 ft lbs at 2500... boo hoo...:D
