Desperate help needed for TBI problem!!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by John B, May 11, 2002.
  1. John B
    John B Registered Member
    May 29, 2000
    6
    Tacoma, WA USA
    To make a long story short my '87 5.7L TBI motor will not start after it has ran for a few miles.
    Here's the details:
    While driving home from work it just suddenly died on the hiway. I towed it home and observed no spark while cranking. I replaced coil, ignition module cap and rotor. Car runs for a few miles then dies again. Towed home again! I replace fuel filter, swap in new computer and swap out fuel pump relay. Same deal! Runs for a few miles (about 15 minutes) then dies and refuses to start! Just keeps cranking
    I check for spark and there is none while cranking. I observe the TBI and no fuel is being dumped. The fuel pump is working (I disconnect the fuel filter and while cranking, it pours!).
    What's the deal?!!!!!!!!!!!!!!!!! I just checked the voltage at the coil and at the injectors and now notice somefuel but the injectors are only getting 9 volts while cranking as is the coil only geting 9 volts. With the ignition in the "on" position, both coil and injectors see 12+ volts. Is the ignition switch on the column hosed somehow?
    HELP!!!!!!!!!!!!!!!!!!!!!!!!
  2. mpascino
    mpascino 1/2 ton status
    Jan 1, 2001
    557
    Connecticut
    Sounds like you have a pickup coil problem in the distributor. After a while the connections inside break. When you changed the ignition mod, you might have moved the wire around enough to make it run again for a little bit. The pick up coil would cause you not to have fuel or spark. They are only like 15 bucks if I remember right. Worth a shot, or try swapping distributors with someone if you can.
    Good luck,
    Mike
  3. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Have you checked the trobule codes? What kind of codes come up. The computer will store trouble codes and not turn on the check engine light.
    For instance: The pick up coil as mentioned above will usually throw a code 42 if bad and may not turn on the "check engine" light
  4. John B
    May 29, 2000
    6
    Tacoma, WA USA
    Well, I replaced the coil pick-up and no change :>(
  5. John B
    May 29, 2000
    6
    Tacoma, WA USA
    Guess I'll get a code reader at Walmart for $20 now and try
  6. smack
    smack 1/2 ton status
    Feb 24, 2000
    277
    Colorado
    I know you said you replaced the module but I had that exact problem and that's exactly what it was. Maybe it's possible that your new module is defective or wasn't installed with the conductive coating??
  7. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Nah, save your cash. The ALDL (assembly line diagnostic link) doesn't need a scanner to give you the trouble codes. Look for that plug below the brake release, thats the ALDL. Take a paper clip and jump the two ports in the upper right hand corner. Do this with the igntion off, then turn it on when its jumped. The check engine light will blink out morse code at you. It will also blink the code three times for you. The first code will alway be 12, one blink, pause, two fast blinks. Try that and spend the $20 on something useful.
    It could be something stupid, I think TBI have a brain that kills the fire if you don't have enough oil pressure. That could be out of wack.
  8. Thunder
    Jul 20, 2000
    8,946
    Northeast Nevada
    Yeah dont spend the money for a cheapo code reader. Just jumper it out as BB said. If you want to get a scanner get an Auto-X ray scanner. They cost about 150 but they tell you about everything you need to know( voltage, operating paramaters ect) about the various controlls and sensors.
    But for starts just Jumper it out and bring up the codes.
    If you dont have a code chart here's a link:<a target="_blank" href=http://www.batauto.com/GM/86-88_578.htm> TBI Trouble Codes</a>
    Get the trouble code and I'm sure somone here can help.
    Note! if you have disconnected the battery or power to the ECM all the codes will be erased.
  9. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    If the computer doesn't see ignition being triggered the injectors won't fire.
    Good luck.
  10. John B
    May 29, 2000
    6
    Tacoma, WA USA
    Mystery solved! I re-traced everything I did and noted that the vehicle wouldn't start at all after replacing the coil pick-up. I pulled the distributor again and put the old coil pick-up back in......BINGO!!! It started! I took back the brand new Borg Warner unit that I had just installed and put in another new one.....now it runs like a champ! I just didn't thinnk I would have to pull the disributor and tear it apart 3 times to get it running right! Thanks all for the help!
