destructive feedback
Discussion in 'Audio' started by stretch67, Oct 4, 2004.
  1. stretch67
    stretch67 1/2 ton status
    Nov 1, 2003
    171
    bozeman mt
    got the system wired up in the burb today. i went to test it before bolting it all down and had trouble! i am using 4 amps to drive different speakers. all 4 have remote turn leads. all are grounded together same with power feeds. here is the problem when i turn on the deck i get a loud low violent rythmic feedback for about 2 seconds. the front speakers shake very bad! then nothing everything works fine. wtf the remotes are hooked up to deck remote out. any advice? /forums/images/graemlins/dunno.gif
  2. RingMaster4x4
    RingMaster4x4 1/2 ton status Premium Member
    Mar 4, 2001
    2,049
    Bartlett, Texas
    I would not ground them together
  3. cochino12
    cochino12 1/2 ton status
    Dec 23, 2003
    563
    Parker, Co
    You might need to run relay for the remote turn on, that will ensure they are all getting enough turn on power. Amps take a different amount of time to turn on, that will cause noise but it's usually "popping" sound that you'll hear. As far as the grounds it should be just fine to have them grounded the same place. Good luck
  4. stretch67
    Nov 1, 2003
    171
    bozeman mt
    thanks!!! there was a relay when i pulled the deck from my other rig that i had a shop install. i didn't reuse it cause a buddy pulled it and i wasn't sure how to wire it. popping describes the sound pretty good! i will try the relay and hope thats the problem! /forums/images/graemlins/woot.gif
  5. cochino12
    Dec 23, 2003
    563
    Parker, Co
    update?
  6. rubbinz raczn
    rubbinz raczn 1/2 ton status
    Oct 4, 2004
    656
    too far north!
    new username! i have had to work so have been driving 67 gmc still not sure how to wire up relay? might have to go to stereo shop but they want 200 bucks to talk to you! anyone know about relays? /forums/images/graemlins/1zhelp.gif
  7. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    A remote turn on relay is not going to solve a noise issue..... /forums/images/graemlins/whistling.gif
    You've got what sounds to be a ground loop problem. Unfortunately, you also have a pretty complex sounding setup, so it will take some time to trace the problem. Is this noise coming out with the engine running, or are you getting it even with the engine off?
    I would start by isolating each amp and seeing if you can trace the noise to a single component. Also, grounding everything together isn't bad...but you need to find a good solid ground to tie all those grounds to, like a clean spot on the chassis or frame. Do NOT run the grounds back to the negative battery terminal directly....you are almost guaranteed to have "alternator whine" by doing that.
    My guess is that you have a bad ground, or a component with poor power supply isolation.
  8. cochino12
    Dec 23, 2003
    563
    Parker, Co
    Greg, not trying to start a pissing match here. But, a relay on the remote turn on will absolutely (sp) stop turn on and turn off "pop". Will it help with the ground issue, NO but he is describing a noise that only happens for a brief period when the amps turn on. Ground loop is a whine that stays on when the vehicle is running and sounds like an audible tach. You are 100% correct about your ground recommendations though. Oh and ground wire should be no longer than 18"
  9. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
    So by using a relay, more power can be sent to the turn on which means it will turn on faster? A friend of mine has the same problem in his car with his amps and we haven't been able to figure it out. I was thinking more along the lines of what Greg said. If you can update us with the fix I would like to hear it.
    -Chris
  10. rubbinz raczn
    Oct 4, 2004
    656
    too far north!
    thanks guys! i have since sold the burb so i gotta start over with the new rig. the system was quiet when running just had the noise at power turn on. so it's the voltage that the relay increases that prevents the pop?
