detailed 14bff disk brake swap??
Discussion in 'The Garage' started by 85mudblazin, Aug 13, 2004.
  1. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Any one have one or can someone give me some info, heres what I need to know, what rotors do I need and how much do they go for?? How do you hook up the e-brake on a caddy caliper?? And how do I get the old drum off???
    -Chris
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
  3. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    yea thanks I found a good one over in pirate.
  4. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    I used 1977 3/4 calipers, rotors and pads. I used a weld on caliper bracket that needed to be spaced 3/4" inside the axle flange- gotta make sure the caliper has room to move toward the center of the truck as the pads wear. New rotors are like $24 each. To get the drum and hub separated just get a bfh and beat the studes though. Careful not to mess up the threads. The rotor goes on the reverse of the drum coming off /forums/images/graemlins/waytogo.gif
