Determining gear ratio
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TX Ranger, Mar 8, 2003.
  1. TX Ranger
    TX Ranger Newbie
    Jan 3, 2003
    3
    79 2wd Jimmy, is the gear ratio identified anywhere? No mention of it on the sticker in the glovebox, dont see any tags on the diff itself. Anyone?
  2. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    I'm betin' on 3:08. You can pull off the cover and count the teeth or jack it up and rotate the tire. Count the tire revs and driveshaft revs and you can come up with the ratio. Post in the Garage section and someone will know specifics on how to do this.
  3. prerunner1982
    prerunner1982 1/2 ton status
    Nov 4, 2002
    235
    Oklahoma
  4. tRustyK5
    Jul 23, 2000
    36,170
    1,375
    E-town baby!
    Pull the cover and check the edge of the ring gear. The ratio will be stamped there along with a date code (build date)
    The last 4 numbers will be the build date (11 78 for example) the 4 numbers preceding the date caode are the ratio of pinion to ring gear teeth. 10 41 is 4.10's, 11 41 is 3.73's etc etc.
    Then clean the guts with some brake Kleen, slap some RTV on the cover and bolt it back up. Add some new gear lube and call it done. /forums/images/graemlins/thumb.gif
    Rene
