Determining what year trany/tcase???
Discussion in 'OffRoad Design' started by DuneRunner, Apr 29, 2003.
  1. DuneRunner
    DuneRunner 1/2 ton status
    Aug 1, 2001
    1,252
    Fremont CA
    I purchased a 465/205 combo from a buddy. He doesn't know what year it was out of. I tried to clean the trany to find the numbers but they are to hard to make out. To Rusty. Is there a way to determine by the Tcase?
    Numbers stamped? or is there a TAG on the 205 like on the 203 or 208s??? I need to spend about an hour cleaning the thing up. Its covered under .5" of dirt and grime... /forums/images/graemlins/eek.gif
    any help would be greatly appreciated... THANKS KEN
  2. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Dune Mullet, I don't know for sure when they changed, but I know that '72 and earlier 465s have the lowwer two bellhousing bolts threaded and the bolts come from the inside of the bellhousing.
  3. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    there should be a tag like all NP203's.
  4. Anthony72K5
    Anthony72K5 Registered Member
    Mar 17, 2003
    20
  5. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    He is refering to the fact that there should be a tag on the 205 just like there is on 203's. Not that it is a 203. My 208 has the tag on the back of the case with the model number, low range ratio, and some other stuff. The tag can be covered in 20 years of crap though, so it can be hard to see.
  6. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    The date usually doesn't matter a whole lot but there should be a tag under the shift rails on the 205 with a date stamp.
    If it has a yoke style front output it's '77 or older, the flat flange happened in 77-78 and up.
    If it has 8 bolts on the front of the 205 it's '84 or older, '85 and up had 6 bolts in a round pattern.
    That's really all that matters when you're working on it.
  7. DuneRunner
    Aug 1, 2001
    1,252
    Fremont CA
    Thank you all for your help. /forums/images/graemlins/cool.gif About a week ago I decided to get dirty and well It took more then a hour to clean. More like 3.
    But it looks good I found the ever so popular TAG under the shift rails. Its Nice and almost NEW looking due to the fact that it was encapsulated in 27 years of DIRT and Grime. It was a 1976 Combo. The trany and T case are going to get new gaskets and we'll see where we go from there.
    Thanks again. KEN
