Detroit Easy Locker Dana 44
Discussion in 'The Garage' started by csnutrition, Jul 13, 2004.
  1. csnutrition
    csnutrition Registered Member
    Jan 8, 2003
    16
    North Alabama
    Thinking about installing a Detroit Easy Locker in a Dana 44 front end. I'm running 36" TSL Radials and was looking for some pro's and cons. I'm not a serious wheeler, mainly hunting and occasional weekend. Are there any tricks to installing. Any advice would be appreciated.
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I have heard someone on here didn't like it. I run one ( gen gear made by tractech same thing )in my rear 12 bolt and love it. Since you do not have c-clips up front , it will be a lot easier . That was the hardest thing I had to do , make sur the c-clips stayed in when putting the rest in. They make a little noise when going around corners slow , as the gears overrun, but beig upfront in slow speeds wheeling I don't think it will bang very often at all . Replace the side gear thrust washers while your in there , and get a new crosshaft/pinion shaft /forums/images/graemlins/k5.gif
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    TheRobZilla runs one in the front D44 and he has beat the hell out of it. His truck is a hardcore rock rig. He runs 35's. He has broken a number of axles an the locker still lives. He had one in the rear 12 bolt though that blew apart in less then 100 feet of use.
    Front yes, rear no.
    Harley
  4. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Unless you already bought it, buy a Powertrax LockRight. At $200 from Jeg's they're significantly cheaper plus they're marginally stronger than the EZ Locker.
    I've beat on my LockRights in both my 10 bolts for almost a year with 33s. No issues yet.
  5. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    You might look into a Power trax Lockrite locker. I think they are better than Detroit EZ lockers. I have known a few people who have broke EZlockers even on light Jeeps.
    Detroit copyed the Lockrite design. There was a law suit between the 2 companies and lockrite won. Detroit had to change the design of the EZ Lock and the new design is weaker in my opinion.
    I have ran a lockrite for over 4 years now with no problems except I had to replace the pinion pin because the extra stress of a locked rear end and hard wheeling wore it out
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Works fine for me in my Blazer , perhaps its driving style . I'll see if my rear one lasts . Looked strong to me in my hand when I put it back in /forums/images/graemlins/dunno.gif
    I am reading some things now. And it seems the guy who designed the Ez Locker left to go work for Powertrax . The lockright is the copy . And its settled now, didn't go all the way to supreme court, EZ locker can stay as it is with no changes. Detroit Ez locker has buttons on the springs so they last longer . /forums/images/graemlins/k5.gif
    Court Documents
    Court PDF
  7. Thunder
    Jul 20, 2000
    8,946
    Northeast Nevada
    I guess I had it backwards. Thanks for setting me straight.
    I rembered reading about the law suit. Its been a while, guess i got the facts confused. Must be old age /forums/images/graemlins/grin.gif
    There is not acually a lot of diference between the two lockers. Its just that I have seen the detroits break before. But I have read a few posts here about people blowing Lockrites too.
    Could be installation. I know with lockrites, they work best if you use a new pinion pin and thrust washers. If you just throw them in an old sloppy wore out rear end they will blow.
