Detroit EZ locker
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlueKnight, Jan 21, 2002.
  1. BlueKnight
    BlueKnight 1/2 ton status
    Mar 6, 2000
    1,518
    Oregon
    Has anyone had any experience with them? Also who knows who to call for the best price on one for a Chev 12 bolt? I spoke to Trachtech today and realy it sounds like a good choice.
    <font color=purple>79' K-5 396cid 600hp, TH350, NP203</font color=purple>
    <a target="_blank" href=http://blueknight.alloffroad.com>http://blueknight.alloffroad.com</a>
  2. white_knight
    white_knight 1/2 ton status
    Feb 23, 2001
    1,171
    Calgary, Alberta,Canada
    Nice name [​IMG]
    Had an easy locker with the 38.5x11 boggers. It is actually only recommended for tires 35" and smaller.
    We had no issues with it. Liked it . Easy to install and not that expensive
    <a target="_blank" href=http://www.whiteknight.scriptmania.com/>http://www.whiteknight.scriptma
    nia.com
    </a>
  3. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    I would do a powertrax Lock-right. Thats what I run, and I have heard they are a better design than the detroit ez locker.
    86Jimmy 4"&35"MTRs,87 burb 4"&33"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  4. BlueKnight
    Mar 6, 2000
    1,518
    Oregon
    I have heard conflicting reports on the power trax line Any problems at all with it? I know it is less money
  5. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    None with mine. I also have a few buddies running them also with no problems.
  6. K5 NUTT
    K5 NUTT 1/2 ton status
    1,611
    Grand Junction Colorado
    I am doing away with my Lockright in favor of a detroit full on locker...the Lockright just won't hold up to 4.10's and 35's....plus the az. rocks don't help either...hehehe. I installed a new carrier...bearings...hardened pin from power trax...and it still chewed inself up...from the extreme use it bevels the side gears and it will unlock at will while cruising or pop so bad backing up you would swear that you just left your rear end scattered all over the parking lot! Just my .02.
    Azblazer
    1979 K5 350 TBI
    1976 K5 Chalet
    If it ain't got arizona pinstriping.....you ain't wheelin the pee outa her!
  7. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    My friend had one in his 12, chewed it up a week later, went to a full detroit after that, another friend has the Loc-rite and has no problems w/ it and he wheels the crap outta that truck, both trucks are on 35" tires.
    Sun Desert Offroad <a target="_blank" href=http://4x4.alloffroad.com>4x4.alloffroad.com</a>
    83 Chevy, 350, sm465, lincoln locked14ff, (soon to be- spooled dana 60, flatbed,and 39.5" TSL's)
  8. Grim-Reaper
    7,385
    Atlanta
    THe EZ for a 10 and 12 rear are JUNK. Robzilla blew 2 and the second one was a mile after he installed it. BigJbear got about 4 good hard rides before his granded. I hear the Lockright does ok but for about $200 more you can go to a Detroit that you will not have a problem with.
    Women dig dents and flat paint!
    coloradok5.com/gallery/Grim
    75 Jimmy, Dollar
    Grim-Reaper
  9. white_knight
    Feb 23, 2001
    1,171
    Wow, you guys all had bad experiences with it.
    Maybe I got lucky with the one I had.
    nia.com
    </a>
  10. Greg72
    Mar 5, 2001
    15,682
    1,392
    642 Days to BB2018
    Dan,
    I really LIKE your new "thumbnail" pic! Kinda like a little "Inspirational" Post-It note for yourself....?
    How close are you now to that D60 now? 50%.....75%....... I'm pulling for 'ya bud! [​IMG]
    -Greg72
    '72 K5 Blazer - 427BB/TH350/NP205/6" Lift/35x12.50's
    <font color=blue>See it here: </font color=blue><a target="_blank" href=http://coloradok5.com/gallery/albun38>http://coloradok5.com/gallery/albun38</a>
  11. Grim-Reaper
    7,385
    Atlanta
    Well maybe you got one of the PRE Lawsuit ones. Seems they were so close to the Lockrights that Lockright sued Truetrack for Pantent infringments and won. I have a Pre lawsuit EZ in my front and it's been fine. I think Robzilla is also running one.
    The bad rears has to small of pins that alingn the two halves of the locker. They are also put too close to the edge. The pin has about 1/32 of metal at the thin spot. WHen they get some good load put on them the pin strats to go sideways and it blows through the thing part and if your luck the pin and springs will not get run through the R&amp;P.
    I can't belive your is surviving the the meats you run.
    75 Jimmy, Dollar
    Grim-Reaper
  12. white_knight
    Feb 23, 2001
    1,171
    I don't have an EZ locker now.It wouldn't last 10 feet. I had it with the 38.5x11 boggers and that was pushing it.
    With the 44's I;m running a Detroit Locker in front and a power lock in the rear
    nia.com
    </a>
  13. Jmask
    Jmask Registered Member
    Jan 16, 2002
    82
    Port Angeles, Wa
    Is that a powertrax or what brand is the power lock your running in the rear?
  14. SCOOBYDANNN
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    SHould be here on Friday, [​IMG] dont know what i should do after that, build the flatbed and exo-cage or get the tires.[​IMG]
  15. Brady
    Brady 1/2 ton status
    May 6, 2000
    628
    Parachute,Co
    I am running the EZ lockers in my rig with a 12 bolt and 44.I have had no problems.I even blew the rear pinion bearings and that ate the gears.The locker didn't show any signs of wear or chips after this.And is still working fine.I am running 36" swampers and wheel hard.I can't complain with them.Blazin
    '73Beautiful Disaster
  16. bigjbear
    Feb 18, 2000
    13,970
    450
    Marietta GA
    Like Grim said mine let go quickly after putting the 35s on. It worked good with 31s, but after a few trips with the 35s it killed its self. The Lock-Rite is the way to go if you want a drop in. I needed a new case when I regeared so I just got a Detroit (full case).
    Jim '80 GMC & '73 Blazer
    Body by Tellico
    <a target="_blank" href=http://www.tellicok5.rockcrawler.com>www.tellicok5.rockcrawler.com</a>
  17. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    The powr-loc was originally a dana-spicer unit, and I believe is only available for Dana axles. I have one in my rear Dana 60 was a factory option. With 130K miles it still tested good per the service manual. How about the "Quick Loc" from genuine gear? Seems to be the new drop in locker kid on the block.
    <a target="_blank" href=http://communities.msn.com/jims70gmc>My 70 GMC</a>
  18. aksidentproan
    aksidentproan 1/2 ton status
    Dec 8, 2001
    477
    Maryland
    If you look at the fine print in some of those ads it says its manufactured by Tractech for genuine gear so its probaly the same as an EZ locker.
    Evan
    1970 Blazer, <font color=orange>ORANGE</font color=orange>, 3-speed manual, NP205, 33" tires <a target="_blank" href=http://community.webshots.com/user/aksidentproan>http://community.webshots.com/user/aksidentproan</a>
  19. white_knight
    Feb 23, 2001
    1,171
    JIMs has it.
    Dana/spicer
    We had extra plates put in it which makes it pretty much locked full time
    nia.com
    </a>
  20. JIMs70K25
    Dec 31, 2001
    524
    Chesapeake, VA
    Now why would they go and do that. Maybe they were distancing them selves from the first E-Z lockers they sold?
