Detroit Install Question
Discussion in 'The Garage' started by willyswanter, Jan 17, 2003.
  1. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Well, I have seemed to misplaced my detroit locker installation instructions and I am at that stage of my gear install as we speak. This is on a 10.5" 14 bolt FF rear. Don't I just drop it in to a carrier half and then bolt the other half on then remove the little bolt that runs through the middle of it to hold it together? I was reading on a site that it had to be taken apart and adjusted and all this junk but I don't remember anybody saying anything about that.... /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif
  2. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    That's what we did to mine. Sounds right /forums/images/graemlins/thumb.gif slap it in.
  3. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    No, do not take it apart. If you do take it apart then it has to be put back together a certain way (the instruction say how, but why bother cince you shouldn't take it apart anyway.)
    Drop it in there, bolt the carrier back together, then remove the little bolt w/ washers through the carrier hole for the axleshaft. That's it.
    -- Mike
  4. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Alrighty then, thanks fellas. Once last thing, I use just normal gear oil with this right? No special additives...
  5. tRustyK5
    Jul 23, 2000
    36,173
    1,384
    E-town baby!
    80W90...no additives.
    Rene
  6. SAVAGE1
    May 22, 2000
    1,104
    BAY AREA, CA
    You can throw some holy water in there for some good luck! /forums/images/graemlins/thumb.gif How did your crush sleeve situation work out?
  7. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Thanks, ok one last question and I promise I'll go back to the garage and leave you all alone /forums/images/graemlins/grin.gif. What is the torque on the pinion housing bolts? The 6 bolts that hold it to the housing? I couldn't find it anywhere...
    I bought a new sleeve at the dealer and got it set right this time. No flying vices or breaking work benches tonight /forums/images/graemlins/thumb.gif
  8. tRustyK5
    Jul 23, 2000
    36,173
    1,384
    E-town baby!
    3/8" bolt...I torqued mine to 35 lbs same as an intake manifold.
    Rene
  9. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Alright, I'm headed back to the bat cave /forums/images/graemlins/thumb.gif
  10. tRustyK5
    Jul 23, 2000
    36,173
    1,384
    E-town baby!
    LOL...keep a sharp eye out for guano./forums/images/graemlins/eek.gif
    Rene
  11. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I hope you remembered to remove ALL of the thrust washers. /forums/images/graemlins/shocked.gif The ones for the spider gears and for the side gears have to come out before installing the Detroit Locker or it won't work right.
  12. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Ummm, huh? I have a brand new empty carrier that I put it in... Was I still supposed to do something?
  13. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Then all should be well. When taking apart a standard open diff to install the DL, you have to remove all of the existing thrust washers. There is one behind each spider gear and each side gear. But if you started with just a new carrier than you're locked and loaded. /forums/images/graemlins/cool.gif
  14. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Whew ok. Don't scare me like that /forums/images/graemlins/thumb.gif. Going to head down right now to run a pattern and see what it looks like /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
