Detroit locker gear oil question.
Discussion in 'The Garage' started by destinbeachman, Dec 11, 2006.
  1. destinbeachman
    destinbeachman 1/2 ton status
    Aug 31, 2005
    365
    Florida
    What brand of fluid are you guys liking in your Detroits?Anyone tried enough types to see any difference?
  2. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    No personal experience yet, but I don't see that the fluid would effect how it performs.
  3. destinbeachman
    Aug 31, 2005
    365
    Florida
    Was thinking that some guys might have noticed less noise with different types.Maybe a certain brand might last longer/look better when changed etc...
  4. steve_kibbe
    Feb 4, 2004
    2,895
    Spartanburg, SC
  5. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    I run 85w-140 with my LockRight, keeps it alittle quieter
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Heavyweight Redline Shockproof . It won't stop an occasional bang , and in a lockright it won't always quiet the slow parking lot corner click with a Lockright . However , noise is greatly reduced overall otherwise .
    It will stay on whatever it touches , I had my other 12 bolt sitting with the cover off for over a year , and its still had Redline clinging to the surfaces .
  7. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Pauly is right on. I use the same Redline Heavy Shockproof gear oil in my K5's diffs with a Detroit in the back & a Lockright in the front. I am a believer in it for offroad diffs. It is not meant for long haul DD action for for a moderate DD & trail rig it kicks arse. It isn't cheap & can be hard to find but it is totally worth it IMHO. It looks like Pepto Bismo & is very thick. It sticks to EVERYTHING though & is great protection for diff that you have spent alot of money on to get locked, geared, etc. The viscocity is 75w-250 :D. Like Pauly said also it quites noisey diffs alot. Until recently I had NEVER heard a peep out of my lockright in 3 years of offroading. Not many people can say they don't hear there lockright.
    In my long haul DD I use Amsoil Severe Gear Synthetic. It has many of the same features as the Redline except it is not quite as thick & is ment for heavy DD use. Amsoil is available in 2 weights. 75w-90 & 75w-140.
    Both oils are designed with very good pressure characteristics. Neither oil will press out from between the metal parts even under extreme load.
    Harley
  8. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    I use the cheap Oreilly gear oil in the 5 gallon bucket. I change my gear oil often due to water crossings and wheeling in mud.
  9. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I use 80-90W dino gear oil. My detroit almost never unlocks unless I am coasting down a hill or something so I cannot help with noise.
    Ira
