detroit locker in CUCV front axle??
Discussion in 'The Garage' started by gtkustoms, Apr 25, 2002.
  1. gtkustoms
    gtkustoms 1/2 ton status
    Oct 6, 2001
    281
    nm
    do the m1008 CUCV's come with a detroit locker in the dana 60 front axle?
    thanks
    travis
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    No.
    They will have either the open dif or a Trac-Lok.
  3. gtkustoms
    Oct 6, 2001
    281
    nm
    was the difference if it was equipped with a traction devise or not would that depend on the m1008 or the m1028? versions
    or some other fluke factor?
  4. AJMBLAZER
    AJMBLAZER Better to be lucky than good. Premium Member
    May 18, 2000
    22,793
    101
    Paducah, KY
    I was told the CUCV 1 tons with TH400's only had a Detroit in the rear axle. The CUCV 1 tons with the SM465's had a Trac Lok in the front as well as the Detroit in the rear.
    Heard that either here or on orc/Chevy, but several people agreed on it.
  5. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    The M1008 is the single rear wheel p/u and the M1028 is the dually
  6. gtkustoms
    Oct 6, 2001
    281
    nm
    i did not know they came with a 4 spd....everyone that i have seen has been auto...other people have told me that they were all autos in the chevy trucks
    the m1028 were lifted versions of the m1008 that were supposed to have lockers front and rear. some m1028 were duallys but others were not
    here is were i read this http://www.geocities.com/MotorCity/Highway/3969/cucvmodels.htm
  7. AJMBLAZER
    May 18, 2000
    22,793
    101
    Paducah, KY
    I seriously doubt the military ever had lifted CUCV's. Heck, the most aggressive tires I ever saw on one in my 4 years in the Marines were some crappy AT's./forums/images/icons/tongue.gif
    The stick CUCV's are rare. I saw one, and over a hundred of the regular TH400 tranny CUCV's./forums/images/icons/cool.gif Main reason being that most people going into the military do not know how to drive a stick, so they don't feel like wasting time teaching Private Shmoe how to drive a stick. Not to mention the chance of Private Shmoe forgetting how to use a clutch when under fire and getting aced would be a problem./forums/images/icons/crazy.gif
  8. gtkustoms
    Oct 6, 2001
    281
    nm
    how do you visually tell the difference between the 1008 and the 1028 SRW versions
  9. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Every CUCV I have seen with locked front and rear axles was a th400/208 or th400/205 combo. The 400/205 is rare in them also. My D60 has the trac lok and it is from a auto truck.
  10. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    CUCV SPECS
    All of the models have a positive traction type rear axle, GM 14 bolt full floating on all except the M1009, which has a GM 10 bolt axle. Front axles are Dana 60 models on all except the M1009, which has a GM 10 bolt axle. The M1028 and M1031 series have positive traction type front axles.
