Detroit Locker inside.....Install questions
Discussion in 'The Garage' started by mrk5, Nov 9, 2004.
  1. mrk5
    Apr 20, 2004
    12,349
    1,050
    Northern Colorado
    Thanks to Tim's Offroad for locker, bearings, seals, & ring bolts. /forums/images/graemlins/thumb.gif
    I feel like I'm entering a new level of the off road driving experience. /forums/images/graemlins/peace.gif
    So basically how hard is it going to be to install this bad boy?
    FYI: It's a C-type locker for a 12bolt.
    I guess my biggest concern is wether or not I'm going to have to set up the gears again. I haven't read the instructions yet (too impatient). Can I leave the pinion be and just bolt the ring gear on with the same shims that were on the old carrier?
    Also, has anyone ever heard of using a piece of paper to set up gears?
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    that will get you close, if not correct. just check the pattern adjust acordingly. /forums/images/graemlins/waytogo.gif
  3. mrk5
    Apr 20, 2004
    12,349
    1,050
    Northern Colorado
    Well I just read the instructions, and they make it seem real simple.
    *Just measure from here to here on the stock carrier.
    *Move everything to the detroit.
    *Measure from here to here.
    *Figure out the difference.
    *Install shims to accomodate.
    *Put the Detroit in.
    /forums/images/graemlins/thinking.gifNow if only it will actually go that smoothly. /forums/images/graemlins/shame.gif
    Any other "things to look out for"?
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Double check your backlash and run the pattern just to make sure. You never know what you're going to get.
    Thanks for the props, and take pictures! I need pics of my customer's trucks for the soon to be released Tim's Offroad website. /forums/images/graemlins/thumb.gif
