Detroit Locker install in a front Dana 60? Shadetree mechanic doable?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BurbinOR, Apr 1, 2001.
  1. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Guys, got my Dana 60 sitting outside in my utility trailer waiting for time to complete a couple of prep things before it goes under the Blazer. Needs brakes, etc.............big question is can a Detroit Locker be put into a Dana 60 much like into a 14BFF? In other words, WITHOUT HAVING TO RE-SET THE GEARS. I would love to do this myself as I am doing all the other work to it, but want to make sure. Or will I have to have the gears re-set by a pro (my engine builder Ben agreed to do it if I need him to, but would rather just drop in a Detroit without doing any gear reset).
    Any other opinions on using a Detroit or should I look at a Tru-Trak or Powerlok? If I use those, I am pretty sure the gears would need to be re-set, right?
    Not worried about the usual "Detroit Locker in the front affecting turn radius" issues. This beast will be used mainly for SAND and whatever trails I use it on I will deal with the turning radius issues. As Ken once said, "drop in a Detroit and forget it". I like this theory...........an ARB is just too costly to justify...........and I like the bulletproof-ness of a Detroit up front.
    TIA..........
    <font color=orange>'79 - 406 TPI -<font color=orange> K5#5 - <font color=blue>See it at---&gt;<A target="_blank" HREF=http://www.blazzinor.coloradok5.com>http://www.blazzinor.coloradok5.com</A>
  2. tRustyK5
    Jul 23, 2000
    36,170
    1,380
    E-town baby!
    As far as I know any traction aiding device for the Dana 60 will replace the existing open carrier, so I would say yes the gears will have to be set up again. I think the 14 bolt rear is the only diff that the carrier is re-used.
    Rene
    [​IMG]<A target="_blank" HREF=http://jules.coloradok5.com>http://jules.coloradok5.com</A>
  3. Brians 60s
    Brians 60s 1/2 ton status
    Jun 12, 2000
    1,115
    Bend, Oregon
    Rene is right. any trac lock, powerlock, or detroit locker in a
    d60 requires scrapping the existing carrier completely and replacing it, so you do have to reset your gears. Just be sure
    to save all of your shims so you have a base to go on for a
    reset. BTW, I don't have a detroit for a 60 but I do have a traclock and a powerlock for one as well as a couple sets of
    4.56s if you are interested. Brian
    "IF YOU'VE NEVER BEEN STUCK.....YOU'VE NEVER BEEN WHEELIN"!!!
  4. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    The only option you have for a locker in a Dana 60 that does not require the gears to be set-up would be a Lock-Right. Different people usually have varying opinions on how a Lock-right will hold up, but my opinion is that they are as strong as the stock carriers (in other words not as strong as a Detroit, but how many people can break a 60?).
    There are two guys in our club with front Dana 60's, one with a Detroit and one with a Lock-Right, and both run strong 454's and around 40" tires. The guy with the Detroit originally had a Lock-right but broke it, though he is REALLY hard (borderline abuse) on his truck. The other guy uses his truck hard but doesn't really abuse it and the Lock-right has been trouble free for several years now.
  5. Emmettology 101
    May 9, 2000
    8,126
    FL
    Detroit is the best way to go if you dont want to mess with an ARB.. From what I heard the Powerlock is next in line sinc eyou can have it rebuilt with more clutches and springs making it will lock harder.
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>
    "He who uses a winch...... Is tired of yankin!"
