Detroit locker Install Question
Discussion in 'The Garage' started by Impex, Mar 24, 2002.
  1. Impex
    Impex 1/2 ton status
    469
    Chandler, AZ
    could the little bit above average backyard mechanic do a detroit locker install on a 14bff themselves or is it better left to a pro??
  2. tRustyK5
    Jul 23, 2000
    36,172
    1,381
    E-town baby!
    The Detroit install on a 14 bolt FF is very easy unless you're doing a ratio change at the same time. There are no side shims to keep track of, no special tools needed except for a torque wrench...
    Here's a link with a great description and excellent pictures for reference.
    http://www.off-road.com/chevy/tech/detroit/
    You do need to start with an open diff'd 14 bolt though.
    Rene
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    Anybody can do it. Just follow the site like tRustyK5 showed you. /forums/images/icons/wink.gif
  4. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    if you dont have an impact, you may want to break loose the carrier bolts while the carrier is still in the truck. they are torqued to 100 ft-lbs or so. just a thought,
  5. greatwhitenorth
    greatwhitenorth 1/2 ton status
    Mar 10, 2002
    102
    Surrey, BC
    I have the G80 in my truck, so when I install a detroit I will need to install it in an open carrier. My question is that when swapping from the posi carrier to an open carrier will it be necessary to adjust the ring and pinion settings when I re-install it in the truck??
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    Yep, you are gonna need to reset the pinion depth and ring gear back lash.
    If this is something you don't feel confident doing, take it to a pro. /forums/images/icons/wink.gif
  7. greatwhitenorth
    Mar 10, 2002
    102
    Surrey, BC
    Thanks, that's what I thought.
