Detroit Locker Question
Discussion in 'The Garage' started by JEBSR, Aug 4, 2005.
  1. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    I JUST SWITCHED TO A 14 BOLTFF WITH 456'S AND DETROIT LOCKER. I HAVE RAN THEM BEFORE AND HAVE ONE IN MY AVALANCHE AND I HEAR IT ENGAGE AND DISENGAGE AT TIMES ON THAT TRUCK. HOWEVER ON MY BLAZER IT IS 4 TIMES AS LOUD AND ACTUALLY CAUSES THE TRUCK TO JUMP WHEN IT DISENGAGES AT TIMES. THIS USUALLY OCCURS WHEN I AM TAKING OFF FROM A DEAD STOP IMMEDIATELY OR WITHOUT 5 FEET. I'M THINKING THAT IT JUST MORE NOTICEABLE BECAUSE I AM RUNNING 38.5" CREEPY CRAWLER AND THEY DOWN SPIN AT ALL WHEN THE LOCKER UNLOADS WHEREAS MY OTHER TRUCK WILL CHIRP THE TIRE AND GO ON. AM I CORRECT OR DO I NEED TO LOOK FOR A PROBLEM? :confused:
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Its normal. In mine if you let off the gas you can hear it clunk and unlock, then when you get back on the gas you can feel each tire lock up, kind of swerves just a hair. Just one of those things that you gotta get used to. :D
  3. Zeitler
    Zeitler Registered Member
    Feb 22, 2005
    99
    Sweden (Northen Europe)
    I have heard that if you have a manual trans , the detroit will be much louder..
    check the oil level in the 14bff
  4. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    Could it be that the one on your avalanche is a newer version, and this one is older?
    I thought, and I may be wrong, that the newer DL's had a little better road manners, than the older ones. Seems like I read it in the paperwork that came with my D60's DL.
  5. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    Ditto ... and I just can't get use to that little swerve, drives me nuts! :dunno:
    Eric M.
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    That is correct as far as I know . Manual loads and unloads the driveline , where an auto , even with the brakes applied , still has the driveshaft working it more constantly .
  7. JEBSR
    Dec 23, 2004
    1,541
    Clarksville, TN
    Detroit Locker
    Thanks Guys, Was Hoping You Would Say It Was Normal. I Am Like You Though That Little Swerve Is A Little Hard To Get Used To. Anyway Thanks For The Info.
  8. highrlr
    highrlr 1/2 ton status
    Nov 29, 2004
    302
    Bismarck, ND
  9. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    The swerve is not bad on icy roads as long as you are used to driving your blazer, I think my Detroit behaves very nicely, drive around a tall samurai with a rear automatic locker for a while and you won't even hardly notice the Detroit in your blazer
  10. JEBSR
    Dec 23, 2004
    1,541
    Clarksville, TN
    It's not so bad that I would be afraid to drive it in icey conditions either. Will drive mine through the winter.
  11. greg mgm
    greg mgm 1/2 ton status
    Apr 6, 2005
    152
    Pine Cove (near Idyllwild) CA
    My 78 truck has a manual, and Detriot. When it "pops" it sound like someone just rearended the truck, very loud. Its been like that since it was installed, around 12 years ago. No problems on ice. I wouldnt have any other locker. (My wife freaks every time she hears it)
  12. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,921
    331
    Fort McMurray, Alberta
    Hmm, this thread is making me have some second thoughts about a detroit. My K25 currently has a Gov Lock posi in it, which I am certain I'll break in the winter. I've got another 14 bolt FF diff with an open carrier in it, heavy duty brakes, and such, and I was planning on just putting a detroit into it. However, this little swerve thing is making me have second thoughts. The roads can get extremely bad up here, break loose even a little bit and you are gonna be in the ditch right now. Will a cheaper Powertrax or something still do that? I'm not gonna be bagging on the truck very much, maybe the occasional mud hole or burnout, so I don't really need a super tough locker like a detroit. The reason I worry about the gov lock is that I regularly spin on one wheel, while the other is on solid pavement, and I am worried that when I launch, I'll break the gov lock with that single wheel spinup.
  13. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    SC, you hit it right on the nose for me...A lot of snow and slippery roads do NOT go well with a detroit. It seems the only other option for a 14BFF is an ARB...and you know that means $$$. But, think of it this way: if you use the detroit, and get into an accident in the winter because of it, the extra cost of a selectable locker makes sense. Now I just have to save up....so many things to get, only limited funds. You don't have a nice dana 60 with 4.10 gears for sale (cheap) do you?????? :D
  14. Russell
    Jun 23, 2000
    7,921
    331
    I wish, lol, it wouldn't be for sale anymore though :D
  15. JEBSR
    Dec 23, 2004
    1,541
    Clarksville, TN
    Detroit
    Keep In Mind Guys That This Thing Does This Pop Just As I Let Off The Clutch On Initial Startup Or Within 5 Feet Of A Slow Start. It Doesn't Just Swerve Driving Down The Road On Me. I Drive It In Rain All The Time With No Problem And Will Be Driving In Ice And Snowy Conditions As Well With No Worries
  16. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    Any automatic locker will do it, and will be exagurated by a manual trans.
  17. paulmoon
    paulmoon 1/2 ton status
    Feb 11, 2004
    211
    Reno, NV
  18. Eric M.
    Dec 10, 2001
    2,118
    Oakland, CA
    Gotta agree here.
    If you're gonna be on icy roads a lot, you'll probably end up regretting the locker. I went from Detroit in the rear and Power Lock in the front to Detroit in the rear and open front and am really considering dumping the Detroit for an ARB. If you go with the locker, take your foot off the gas when ever entering the slightest of turns. You get use to it, but, it isn't as stable as both front and rear diffs. being open. It's all over once the rear tires break loose, you could just spin around and stop or you might end up on the wrong side of the road with a big rig heading your way :doah:
    Eric M.
