Detroit Locker Vibration?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by kpanza, Aug 23, 2001.
  1. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    Ok, here's a question that has to do with the dreaded driveline vibration! I went from a 4" lift to a 6" lift last December. This was done with 6" Superlift Superride front springs and an ORD 4" shackle flip + 2.5" Superrides out back. At the same I swapped in a 14bff with a Detroit Locker rear and converted to 8 lug 10 bolt with ARB up front. Upon driving the thing for the first time, it vibrated horribly! So, we lowered the t-case by turning the stock spacers over underneath the frame. That helped a bit, but didn't get rid of the vibes. Then I installed some 3 degree shims under the rear springs, that again helped, but didn't stop the vibes. It doesn't vibrate very bad except when in that "zone" between on the gas and off the gas, you know, when you let off suddenly and then as you get back into the throttle. So, then I tried some 4 degree shims, same effect - a little better but still no cigar. So, last night I swapped in some 6 degree shims - this brought the angles of the rear diff and t-case output to 1 degree up (rear axle) and 1 degree down (t-case) - keep in mind that this was done on an unlevel driveway so my main concern is that the angles are damn close to one another, that is the key! So, I go drive it and it is still doing the vibe thing when off the gas/on the gas.
    So, I am wondering, do any of you guys with Detroits have a similar vibration? Is this something that I should just put up with? I have broken u-joints in the past at speed and I don't want any more of that, so that is why I keep trying to fix the vibes. Thanks for any ideas/help. I am getting ready to just say to hell with it all and get a CV shaft and turn the axle up, but I would much rather spend that big $$$ on something else if I can! [​IMG] And if that didn't cure it would be pissed! [​IMG]
    Oh, and by the way, this IS a brand new driveshaft with brand new u-joints (I munched the old one on some rocks two weeks ago), and the vibes have been present ever since the lift last year. If it is just the Detroit doing its thing with its built-in "slop", I guess I can put up with it, but whatever it is it really drives me crazy!!
  2. californiak5
    californiak5 1/2 ton status
    Oct 25, 2000
    820
    Oceanside, Ca. 92056
    Maybe....................hummmmmmmmmmmm........................mufler bearings..........J/K
    I wouldn't have a clue. Sorry.
    The CV shafts from High Angle Driveline are very nice thou, I can vouch for that.
    See Ya,
    Keith
    [​IMG] <font color=green>Born to Drive My K5</font color=green> [​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/californiak5>CaliforniaK5's Pictures</a>
  3. OneLeft
    OneLeft 1/2 ton status
    Aug 14, 2001
    111
    Colorado USA
    In the past I have replaced worn out u-joints with new u-joints that were not that much better than the worn out ones. From what you describe, it sounds like a u-joint to me. I have a 14FF w/detroit locker and 4" lift superlift springs, and I have no problems like that.
  4. kpanza
    Dec 8, 2000
    1,579
    Nope, keith, I KNOW it isn't the muffler bearings, as I change those out every month! ha,ha [​IMG] And that is right after I adjust the "double kickback reverberator" and top off the ol' blinker fluid! But seriously, does anyone have any ideas?
  5. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Are you still running the stock case? For an '86 I am guessing a 208 w/ a slip yoke output. (Side note: see what happens when you fill out your profile, even though he didn't say so I know he has an '86. Makes it much easier to comment. I'll get off my soapbax now.) That might be at least part of the problem. My '80 (slip yoke) has some vibes inspite of the shims &amp; case drop. Not as bad as before I made the corrections, but still there. My '73 (fixed yoke) does not viberate, even with the old u-joints &amp; the case where it belongs. Both have 4" lifts.
    Also make sure you keep the joints greased. I do mine at every oil change. Sometimes in between, too, if I run through a lot of water.
    Jim '80 GMC & '73 Blazer
    Tread Lightly!
    <a target="_blank" href=http://www.gmck5.rockcrawler.com>www.gmck5.rockcrawler.com</a>
  6. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Keith, put a 4" TC all spring lift on three months ago..........they come with some degree shim which I do not know what %, while adding a Detroit-equipped Wes special 14BFF.........no vibrations ever. Very rarely do I even hear/feel the Detroit doing its thing. Transfer case (NP 203) is dropped the 1" spacer width..........and I actually never even have checked the degree difference front ujoint to back.
    Q - was the driveshaft new when you did the lift? Might have been improperly balanced?
    Anyway, we have all heard of this vibration thing with the shackle flip, which was a major reason I went with a rear spring lift. Let us know what the solution is............[​IMG].
    <font color=blue>'79 ONE TON TPI K5 - See it at---&gt;<a target="_blank" href=http://www.blazzinor.rockcrawler.com>www.blazzinor.rockcrawler.com</a>
  7. kpanza
    Dec 8, 2000
    1,579
    Good point about the slip yoke, you are probably right. That is kinda why I would like to swap a dodge 208 in there. As for greasing the joints, most of you will think I'm extremely anal (or nuts), I grease them every 2 weeks or every 4x4 trip (whichever comes first!) I have a very black underside where the extra grease flings up after each greasing! [​IMG] So, I can always rule out the un-greased u-joint problem (I blew one out one time towing a trailer and it was due to being dry + an uncorrected angle problem, so I learned my lesson about the grease!)
    I might have to really look into that fixed yoke Dodge 208...unless Drivelineman can hurry up with the SYE kit (and make it affordable)
    Thanks for the responses, if anyone else can shed some light on this I would really appreciate it!
  8. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    I am in the process of gettin my 208 converted...it should be done at the end of the day today...some of the mods required were to machine down the speedo gear housing to fit in the dodge housing, cut off move and reweld bracket that holds the bar inside to move the shifter on the back side of the T case..(keep in mind i had to use the back half of a 208 for a dodge since the Chevy's oil return goin into the tail shaft dident line up and the case half is not thick enough to redrill the holes. I am thinkin i would have been better off to give advance adapters a call and get a adapter to get a 700r4 and 205 adapter...would have made life alot easier and posibly cheeper...as of right now the bill for the 208 converson sits at 600...and i still need to get a drive shaft built....but its only money...cant take it with ya!
    [​IMG]<font color=blue>Donations accepted for the "Build Chaz's 1972 K5 fund"!!!</font color=blue> [​IMG]
  9. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    You could go with the Tom Woods shaft with the CV slip yoke style. This would give you a new slip yoke and it would give you the CV to help eliminate the vibes. Captcrunch got one and says it rocks. he's running a 6" lift too If I remember correctly. Adn the shaft was $325 delivered to his door.
    What is and what should never be....
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
  10. kpanza
    Dec 8, 2000
    1,579
    I am thinking about the CV shaft, but I think if I am going to spend money on this, I would want to get rid of the weak link once and for all - the slip yoke.
    As for the driveshaft, it was not new at the time I did the lift (I only went from 4" to 6" lift, so it was still fine). But the shaft that is in there now is BRAND new as of last weekend! It's got a new slip yoke and new Spicer joints, brand new everything, professionally balanced, etc. And this vibration has been present since last December, so it has stuck around for both driveshafts, so I think I can rul out the u-joints, shaft, etc - but the slip yoke could be the ultimate culprit here...I'll let you know if I EVER figure it out!
  11. Russ
    Russ 1/2 ton status
    509
    Summerdale AL
    Keith,
    I would bet on it being the slip yoke also. My Blazer did the exact same thing after I lifted it. It would vibrate on decelleration and nothing that I did would get rid of it. It went away when I put the Doubler in with the fixed yoke.
    Russ
  12. bigblue
    bigblue 1/2 ton status
    Dec 6, 2000
    658
    southern california
    Keith,
    I am experiencing the same thing. I have the 6 inch lift. And uhh, yeah that is a 4 degree wedge i thought...uh, yeah...Anyway, When Mike and I rewelded the perches my vibes totally went away. Then I raised my T-case back and I have a small amount of Vibe, I think when I get wedges under I will be able to run it vibe free and t-case up. Even now it isn't that bad..
    The only thing is that I cannpt keep my t-case from leaking...Such a pain in the ass...
    Surfing is Life...
  13. kpanza
    Dec 8, 2000
    1,579
    Yeah, I put in the 6 degree shims and it is pretty good now, especially if I have weight in the back. I went up to Big Bear last weekend and with all my tools and coolers, etc it didn't vibrate at all, so I think it may finally be fixed. But I hear you on the t-case leak!! Mine has leaked since I got the damn thing! I have resealed it and resealed it, but it is a mess! I am seriously thinking about swapping to a fixed yoke 241 when/if I do the Klune V swap! [​IMG]
  14. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Try a new yoke for the leak. Thats what it took to fix mine. It was Spicer and not enpensive.
    Tread Lightly!
    <a target="_blank" href=http://www.tellicok5.rockcrawler.com>www.tellicok5.rockcrawler.com</a>
