detroit locker
Discussion in 'The Garage' started by digity, Jan 22, 2005.
  1. digity
    digity 1/2 ton status
    Oct 10, 2004
    184
    13
    Brentwood Ca
    What's the difference between a detroit locker and a detroit truetrac? I assume the locker is just that but the truetrac, is that a limited slip? Also just got my ff14bolt back 4:56gears and detroit locker. I took the cover off and it looks the same to me. I know how to check the ratio but how bout the locker? :crazy:
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    check and see if you can see the spider gears in the little holes that are in the carrier, if you see smooth shiny metal there is a detroit in there.
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    A truetrac is a limited slip and a no slip is a locker. Pick one rear tire up off the ground with 1 tire on the ground. Put the truck in neutral (not running) and spin the tire in the air. If it spins with force then it is a limited slip. If it locks up and wont spin it is a locker.
    A tight limited slip may not slip either but even then it will usually slip. A lockered axle may spin for a little bit then lockup and will stop spinning. Detroits lockers, especially in 14bff can have a decent amount of freespin before they lock together.
    Harley
