detroit locker?
Discussion in 'The Garage' started by berserker, Jun 21, 2006.
  1. berserker
    berserker 1/2 ton status
    Nov 19, 2005
    127
    columbus,ohio
    why do people not recomend useing one of these in the front axle?
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Harder to steer...
    That said, I have one and love it
  3. berserker
    Nov 19, 2005
    127
    columbus,ohio
    so is that the only reason?
    also if you use a spool in front the wheels wont turn if hubs are unlocked but if locked they will chirp when turning is this right?
  4. readymix
    May 30, 2004
    6,706
    26
    There will be no difference between an open or locked front as long as the hubs are unlocked
  5. berserker
    Nov 19, 2005
    127
    columbus,ohio
    but with the locker if the hubs are locked it will not chirp the tires cornering but the spool will right? and thats pretty much the only difference
  6. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    If you have a locker or a spool especially in the front axle with the hubs locked on pavement you are going to have a VERY hard time steering. I drove onto the street onetime on with the truck still in 4x4 and a front locker and it wouldn't turn for crap. I had to kick the tcase out of 4x4 to get the power off the locker so it would unlock.
    I have a lockright locker in my front axle (acts the same as a detroit will) and LOVE it for offroad driving. It can make steering harder at times but the extra traction the locker provides offroad well outweighs the extra steering input required at times.
    Harley
  7. berserker
    Nov 19, 2005
    127
    columbus,ohio
    thanks for helping me clear that up guys
  8. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    ive got one in the front of mine. hydro assist helps with the steering
  9. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    Because they are afraid they will get too deep into the bush and never find their way out.
    Another reason is: It could cause you to make the cover of an off road magazine.. which might be seen by your boss, whom you told you were too sick to work that day.
    :thumb:
    In all seriousness, like they said, the steering is usualy the reason given.
  10. onetonbb74
    onetonbb74 1/2 ton status
    Dec 1, 2005
    2,083
    Campbell, CA
    Locker in the front is fine if your on mud, sand, anything other than dry dirt or asphalt. Otherwise i just lock one hub at a time as needed, lockers are good for that. If you engage the front end with a front locker on the street, it might not turn at all, my truck just wants to stop if i turn the steering wheel, and go straight when i give it gas. Just get one, there good for any type of 4 wheeling and will make your truck go damn near anywhere.
  11. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    I accidentally left 1 hub locked and when I went on the road... laid into the throttle and the truck actually walked to the opposite side..I pulled over and notice it was still locked... my right hub was locked and the truck lunged to the left.. that is what I mean by walked... :crazy:
  12. loafer
    loafer 1/2 ton status
    Aug 19, 2003
    634
    Lyman, Maine
    I have a No-slip (lockright) up front and it's not too bad on the pavement even with the hubs locked. 2wd of course. I feel a slight pull in the steering wheel but that's it.
    I drove the truck in front-wheel drive recently (removed rear drive shaft) on the pavement and it really wasn't bad at all. No problems on the corners, but I was real gentle with the throttle.
