Detroit Lockers Questions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Big10, Jan 13, 2003.
  1. Big10
    Big10 Registered Member
    Aug 30, 2002
    84
    Georgia
    Friend of mine said that he has owned trucks with Detroit lockers installed in the front axle. I didnt think Detroits would work in the front because the way they work wouldnt allow it.???whats the deal? I am getting ready to go to a different gear setup and I want to install lockers at the same time...cant afford ARB right now. Are there different types of detroits that may allow a front setup?
    /forums/images/graemlins/ears.gif
  2. tRustyK5
    Jul 23, 2000
    36,166
    1,364
    E-town baby!
    A Detroit in front works exactly like a Detroit in the rear...
    Rene
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    A Detroit Locker will function properly in the front. It just makes it pretty tough to turn in 4WD, especially in mud, snow, gravel, etc. The locker tends to stay locked so the front end doesn't go where the tires are turned. It wants to keep pushing straight. On hard surfaces it makes it very hard to turn the steering wheel at slow speeds. A hydraulic ram steering assist, like the one from West Texas Offroad, will solve that problem.
  4. Big10
    Aug 30, 2002
    84
    Georgia
    okay...my next dumb question...Doesnt Detroit make different types of lockers? like EZ Lock, soft lock...Is there one in particular that I would want or has the best reputation? Maybe some that I should stay away from?
  5. tRustyK5
    Jul 23, 2000
    36,166
    1,364
    E-town baby!
    There are lots of different lockers available. Where and how you wheel should determine which one you choose. The EZ locker is generally only good for light rigs on 31's so forget that one...
    What are you planning on wheeling? Tire size?
    rene
  6. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Their most rugged one is the Detroit Locker. There's also a new "soft" version of the Detroit Locker that doesn't make as much noise when it engages. You can check out all their stuff at www.tractech.com /forums/images/graemlins/cool.gif
  7. Big10
    Aug 30, 2002
    84
    Georgia
    thanks for the response,
    I'm running 35 inch M/T's. Wheeling will be mainly mud and "some" hills and "some" sand. No snow. The truck is not a daily driver, but gets about half its miles on pavement.
  8. tRustyK5
    Jul 23, 2000
    36,166
    1,364
    E-town baby!
    A limited slip front or Detroit would be perfect...hell you could run whatever you want up front really. The detroit is the stoutest unit available. The limited slip would be more steering friendly though. As you know there are trade-offs with everything...
    The best of both worlds is a selectable locker like the ARB, but it is expensive in comparison to most other traction aids.
    I'd lean towards an LSD for what you want to do.
    Rene
  9. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    I run a very similar setup as you. I have 35 BFG MTs. Run mostly mud and trails, little rocks, some sand, no snow. I have run a full Detroit locker in front for over a year now. I can feel the impact on my steering when in 4WD. On the road in 2WD or unlocked, there is no difference whatsoever. I usually lock my hubs for offroad, but only shift into 4WD when it is necessary or I know that it soon will be. This helps the turning radius some.
    I would recommend either a full locker or a mechanical selectable locker (don't know what axle you are running) over a limited slip. They cost just about the same to install. It would suck to spend the moeny and then be disappointed or later say "I wish I had...". I would not recommend an ARB. That used to be all I ever wanted. After seeing some of the serious problems friends have had with their while off road, I wouldn't invest the money in one.
    My .02
  10. Big10
    Aug 30, 2002
    84
    Georgia
    Tx85gmcguy...what gears are you running with your 35's?
    I have D44 front and 12B rear.
  11. fourwheelerjeff
    fourwheelerjeff 1/2 ton status Staff Member Moderator
    Nov 16, 2001
    3,419
    6
    meadow, tx; in the boonies
    he was running 10 bolts front and rear with 4.56's and detroits, they are/were for sale in the for sale forum, he is going 60/14 with 4.56's /forums/images/graemlins/pimp1.gif
  12. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    With the 60 I think you can get away with a lunchbox locker. I run a Dynotrax locker in my front and it has held up fine for around a year now.
  13. txbartman
    Jun 1, 2001
    1,975
    Plano, TX
    Yep, Jeff is right. 4.56 fr & rr 10bolts. They are sold, but still under the rig for the rest of the month. City gets really pissed if I have it on blocks with no axles for a month! Should be done with the 14bFF/D60 by the end of the month. The D60 will be open, but the 14bFF has a full Detroit again.
