detroit noise?
Discussion in 'The Garage' started by johnathan, Nov 12, 2005.
  1. johnathan
    johnathan 1/2 ton status
    Sep 26, 2005
    376
    Ocean Springs,MS
    Does the detroit locker affect the amount of noise from the gears at cruising speeds?My dad and I rebuilt my 14 bolt and theres a faint whining at higher speeds ,not very loud at all.
  2. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    Mine doesnt whine at all.
  3. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    did you remove the gears? if there not properly setup then they wil whine. the only thing you will hear from a detriot is a clicking aorund turns (i cant hear mine but some people can)
  4. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    Did you change or rotate tires at the same time? Making sure it is the rear end and not a tire that got swapped side to side, if I do that, mine sounds like an airplane for awhile. Other than that, I believe a whine is incorrect backlash, or a pinion bearing.
  5. johnathan
    Sep 26, 2005
    376
    Ocean Springs,MS
    yeah complete rebuild.I was reading somewhere ,I forget,but it said an amount of noise should be deemed acceptible from a ring and pinion.We where very careful in the rebuild ,the wear pattern looked great ,the backlash was to specs,the pinion had right preload.
  6. mrk5
    Apr 20, 2004
    12,331
    1,039
    Northern Colorado
    A shop installed my new gears, and there was a slight whine. Sound kinda reminded me of a transfercase in low range.
    The pinion seal started leaking, so I took in to another shop. The first place had not crushed the crush sleeve properly and tried to use shims to make up for it. That resulted in the pinion nut loosening up.
    The sound is gone now.
    The problem was actually manufacturing, and then the first shop not knowing any better and not having the right tools. The pinion was slightly too large, so there was no way they were going to get the bearings to seat properly. The second shop had to use the lathe to take a couple thousandths off the pinion, after that everything went in just fine.
