Detroit NoSpin same as Detroit Locker
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Impex, Jun 11, 2002.
  1. Impex
    Impex 1/2 ton status
    469
    Chandler, AZ
    ordered a locker for my 14BFF and i wanted a detroit locker(what i asked for when ordering) but the box that it was packaged in has 3 little check mark boxes
    truetrac
    nospin
    detroit locker
    and the nospin box was checked, but the locker itself looks just like the one shawn did on ww.offroad.com so is it the same thing? whats the difference?
  2. blk87K5
    blk87K5 1/2 ton status
    Dec 26, 2001
    1,290
    Lubbock, Texas
    I think they perform the same function, but the no-spin designation is for heavier truck axles. They must consider a 14 bolt a truck axle.
  3. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I ordered the same and received the same when I did mine.
    Tractech’s locking differentials are the NoSPIN® and Detroit Locker® brands (same product, different market segments).
    NoSPIN® / Detroit Locker® : The most rugged positive locking differential, and most widely available for axles from 3,000 to 70,000 lb. capacity. For severe operational conditions.
    And most importantly :
    Driver may hear and feel "backlash" going from drive-to-coast and coast-to-drive, as reversing torque flow resets the components.
    It gets a litle softer as it breaks in... or I'm just getting used to it!
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    From what I've seen, it seems that if it comes with a complete new differential case, then they label it a Detroit Locker. If it's designed so that it drops into an existing differential case, then they label it a NoSpin. Either way, the mechanism works the same. /forums/images/icons/cool.gif The one for my 14-bolt also said it was a NoSpin. /forums/images/icons/cool.gif
  5. Grim-Reaper
    7,385
    Atlanta
    My full case Detroit for my 12 bolt instruction manual is titled Nospin. The drop in for the exsisting carrier is called a EZ locker. I think Nospin and Detroit Locker are the same thing with two names.
  6. Impex
    469
    Chandler, AZ
    hey guys thanks for the quick replies, i wasn't sure there at first /forums/images/icons/confused.gif well i have today off i better get outside and install this thing, times a wastin /forums/images/icons/grin.gif
  7. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Isn't the EZ Locker is one of those Lock-Rite sorta things? The NoSpin/Detroit Locker for the 14-bolt FF requires the diff to come out, then come apart. Then you replace all the guts of the diff with the stuff that came in the box. It isn't quite as easy to install as the lunch time lockers. /forums/images/icons/wink.gif But I found the owner's manual from when I bought my locker and it shows pictures of a NoSPIN both with and without a case, so that theory is out the window! /forums/images/icons/shocked.gif
    Aha, I just noticed a small note at the bottom of the cover page: "Detroit Locker is a term applied to NoSPIN differentials by some on-highway users. The "Difference" between the two is in name only. NoSPIN and Detroit Locker are thus referred to synonomously throughout this manual"
    Mystery solved. /forums/images/icons/cool.gif
  8. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    NoSpin and Detroit Locker are two different names for the same thing.
  9. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Uh yeah, I thought that's what this said: </font><blockquote><font class="small">In reply to:</font><hr />
    [/ QUOTE ] /forums/images/icons/wink.gif /forums/images/icons/cool.gif /forums/images/icons/wink.gif /forums/images/icons/cool.gif /forums/images/icons/wink.gif /forums/images/icons/cool.gif /forums/images/icons/wink.gif /forums/images/icons/cool.gif /forums/images/icons/wink.gif /forums/images/icons/cool.gif /forums/images/icons/wink.gif /forums/images/icons/cool.gif /forums/images/icons/wink.gif /forums/images/icons/cool.gif /forums/images/icons/wink.gif /forums/images/icons/cool.gif /forums/images/icons/wink.gif /forums/images/icons/cool.gif /forums/images/icons/wink.gif /forums/images/icons/cool.gif /forums/images/icons/wink.gif /forums/images/icons/cool.gif
