Diagnose This ('90 350 TBI) *UPDATE*
Discussion in 'The Garage' started by Bubba Ray Boudreaux, May 18, 2004.
  1. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Diagnose This (\'90 350 TBI) *UPDATE*
    This ought to be a hoot so here we go.
    Vehicle: '90 3/4 ton 4wd with 350 TBI, 4 SPD manual well abused farm truck.
    Problem: It ain't running.
    This is my brother's truck. He thought it was the fuel pump, so after replacement, it still ain't running.
    Knock sensor was replaced in conjuction with the fuel pump because when he replaced the engine, he didn't know the knock sensor was a needed item. I hooked the new sensor up last night, is the plug suppose to be a bare, needle looking thing? My thought is that there used to be some sort of rubber cover over this.
    So the truck wasn't running, narrowed down to there's no power to the fuel pump, since it's not running with the key on. Today, he said he is not even getting a check engine light.
    One thing we found last night was a wire (orange with black stripe IIRC) going into the fuel pump relay had been wrecked, showing bare wire which occured because apparently the air filter housing turned around /forums/images/graemlins/confused.gif.
    I'm at a lost, and I'm the one who's got the knowledge to get us this far, but don't have the truck running yet.
    Thoughts, ideas????????????
    5/21/04
    I mentioned the bare wire up above. I had called my father in law Monday night, and he told me the fusible link was probably the problem.
    Well last night, we went back down and a buddy that is good at this electrical stuff started chasing stuff and I show him the wire. With a disbeleiving audience gathered around (except myself), he showed the world that in fact this was the problem and in fact the fusible link had gotten killed by this bare wire. So in the end, my brother gets all kinds of grief for not listening to the more intelligent folks and I get a free spare fuel pump. /forums/images/graemlins/thumb.gif
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Re: Diagnose This (\'90 350 TBI)
    Is there a fuse for that fuel pump wire? Are you getting power in and out of the relay?
  3. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Well, since y'all are in Okie Land, check to see if there's an engine under the hood.... /forums/images/graemlins/grin.gif /forums/images/graemlins/rotfl.gif
  4. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    check the fuse, if power there then checkthe relay, physically pull the square plastic cover off of it make sure itworks as advertised. if not replace itif yes then make surethat you get power fromfuse to the relay and make sure there is power coming from where ever it comes from to activate the relay. then check continuity between the relay and the pump. and check the ground for the pump also.if relay is not being activated find out why now that your this far, you will need a wireing diagram, I prefer alldata, its very indepth for things like this ???pm me, I'll get back to you as soon as I can /forums/images/graemlins/waytogo.gif
  5. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
  6. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    Hey buttmunch, if I wanted your answer, I would have given it to you /forums/images/graemlins/waytogo.gif
    Forgot to add one piece of information, checked all fuses since this POS doesn't have a fuse labeled for the fuel pump. There was one that was not working, it was the SGL LGHT fuse. The book said that the fuel pump fuse should be 20 amp, checked all of those, all were good.
  7. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    Check for power in and out of the relay next.
  8. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    Nada coming out of the relay............
  9. kennyw
    Jun 9, 2002
    13,223
    94
    Any power in with the key on? Should actually have 2 wires with power when the key is on and only 1 when the key is off.
  10. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    The wire you said was wrecked goes directly to the fuel pump. You can jump from the battery to that wire and see if the fuel pump is working properly. Have you checked any of the fuse links on the fire wall?
  11. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    Does the truck have any power? Sounds like it could be a bad ground.
  12. muddbudd72
    muddbudd72 Registered Member
    Dec 3, 2003
    55
    port allen louisiana
    i recently had the same problem with my 90 blazer with the 350 and tbi. changed fuel pump, relay, and oil pressure sending unit. changed ignition module and has run fine since. module sends signal to emc to fire injectors. it would run for a few seconds whn gas was poured down the tbi. hope this helps.
  13. scoutillac
    scoutillac 1/2 ton status
    Feb 24, 2004
    423
    Spokane, Wa.
    My 88 tbi would run good with a squirt of starting fluid. But if you shut it off you would have to squirt it again. Turned out to be the fuel sending relay. 14.00 at Motion Auto.
  14. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    It's got power, but no power to the fuel pump.
  15. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Check your ignition module like Mudbudd says. If it goes out, the ECM will cut power to the fuel pump/relay to keep the engine from flooding.
  16. justinf
    justinf 1/2 ton status
    Sep 23, 2003
    684
    Tuscola, Illinois
    You should have power with the key off to the orange wire at the relay. With the key on, there should be power on a green with black stripe wire. With the key on, check for power on both of these, if you have power on both of them, then check for power on the tan with white stripe wire, this should be the wire going to the fuel pump. If there is no power on it, then I would check to make sure the black wire going to the relay is grounded. If it is, then I would say the relay is bad.
  17. shaun
    shaun 1/2 ton status
    Apr 22, 2003
    745
    I also had the same problem. I had blown my ecm or ecmb fuse ( the one for the fuel pump). Replaced that fuse and all was good.
  18. bigburban383
    bigburban383 1/2 ton status
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    Fix that broken wire. Make sure your oil pressure switch is connected. You can bypass the Fuel Pump Relay (factory bypass), jump power to that extra wire sticking out of the relay located on the firewall towards the passenger side. If you have access to a wiring diagram it would be very helpful....check that, you also have to know some electrical diagnosis. A knock sensor would not prevent the truck from running. So if the fuel pump does not work after that bypass, its probably a bad wire, like a ground rusted. Look back under the rear driverside wheel well and check for that ground on the frame. If it all possible, check the wiring harness at the tank for power to the pump. Once the pump starts working, crank the engine and watch the injectors for fuel spray. If it don't start then its ignition related. Good luck.
  19. Thunder
    Jul 20, 2000
    8,946
    Northeast Nevada
    Did you check all the fuses?
  20. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    Are you sure? When I had an ignition module go out a few years ago, I didn't lose power to the pump. /forums/images/graemlins/confused.gif
    Yup.
