Diagnose this sound =/
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TXsizeK5, Jun 13, 2002.
  1. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    While driving on the free way I turn about 3k at roughly 65-70mph in 3rd 1:1 in my SM465... My question is when i left off the gas it gives me this noise like a metal brush scraping on a sheet of metal. Almost sounds like really bad high pitched windnoise. This only happens when i let completely off the throttle. Does anyone have any idea what could be wrong? thanks!
  2. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    u-joint maybe?
  3. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    It shows you have a 6" lift - are your driveline angles in phase? Mine made that sound you decribed after I lifted it, it took some shims to get them back in phase. I have heard of u-joints going bad make some funny noises also, might want to check them quick!
  4. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    Check your fluid in the t-case to see if it is low. Especially if it is a 205.
  5. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    How do I check for bad U-joints and Driveline angles? I have a 208 i think, but I'll check. Thanks for the responses.
  6. smartpatrol
    smartpatrol Registered Member
    Feb 6, 2002
    86
    Ault CO
    If you really want to hear it put it in 4 low and let off the gas. My np208 makes a lot of noise like that.
  7. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    To check your U Joints, take a drive for a few miles, then slide under the truck and carefuly feel them. If one is alot hotter than the rest it's going bad. Also grab the drive shaft and try and move it up and down and sideways. Shouldn't be much if any play in the joints. Jack up the back putting jack stands under it, with the parking brake off and the trans in neutral, turn the shaft it should turn smoothly once you take the play in the rear end out. If you know someplace you can get it up on a hoist then also spin the drive lines with the axles at full drop. That will check for binding there. Also at the same time take a strong light and look at the ears that the joint attaches to, look for contact between the shaft and flange sides. /forums/images/icons/wink.gif
