Diameter of the stock dual exhaust?
Discussion in '1982-Present GM Diesel' started by AJMBLAZER, Feb 21, 2007.
  1. AJMBLAZER
    AJMBLAZER Better to be lucky than good. Premium Member
    May 18, 2000
    22,793
    101
    Paducah, KY
    Can someone tell me the inside and/or outside diameter of the stock dual exhaust on a 80's GM diesel or a CUCV if they're different?
  2. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    2.5" and I think that's I.D.
  3. filo
    filo Registered Member
    Mar 11, 2006
    96
    Anoka, Minnesota
    My '86 M1009 CUCV Blazer is 1 7/8" ID and 2 1/4" OD. I'm almost positive the M1009 CUCV Pickup is the same. I can verify tomorrow at work.
  4. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    My '90 with the 6.2 had 2.25" pipes from the factory.
    For the post about the pipes having 1 7/8" ID and 2 1/4" OD....man, that's some super beefy exhaust tubing! That's like 3/16" wall...heavier than any rollcage tubing you normally use.
  5. AJMBLAZER
    May 18, 2000
    22,793
    101
    Paducah, KY
    Mine seems to be 2.5" ID inlet and 2.25" ID outlet at the muffler. I found a Cherry Bomb application that should fit it exactly perfect.
  6. tRustyK5
    Jul 23, 2000
    36,184
    1,388
    E-town baby!
    I wouldn't recomend any sort of "Glass pack" muffler...it'll eventually clog with soot.
    I'd use a chambered muffler, or something diesel specific.
    Rene
  7. AJMBLAZER
    May 18, 2000
    22,793
    101
    Paducah, KY
    I guess I don't understand how a chambered muffler wouldn't clog with soot either...other than more interior space to fill?
    I like Magnaflows but the $80 each puts me off. Still saving the pennies for one for the wife's truck.
  8. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    The glasspacks clog very easy, the chambered mufflers will always have enough room to flow, a film of soot on the walls will not stop the flow, but soot in fiberglass will.:o
    Stick with chambered, you'll end up paying more with glass packs in no time.
    :D
