Diamonds are Forever!
Discussion in 'The Garage' started by Chevy305, Sep 18, 2006.
So uh, yeah...
  1. I love it!
    9 vote(s)
    17.0%
  2. Will you make me some?
    8 vote(s)
    15.1%
  3. They suck! They belong on a ricer
    11 vote(s)
    20.8%
  4. Finally something I can use my FLITZ on
    8 vote(s)
    15.1%
  5. Paint it flat black or OD because thats what the little voices tell me to do
    11 vote(s)
    20.8%
  6. Um, Nekkid!!!!!!
    11 vote(s)
    20.8%
Multiple votes are allowed.
  1. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,230
    488
    New Hampshire
  2. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,602
    554
    Wasilla AK,
    it almost looks like that diomond plate "sticker" Vinyl
  3. Chevy305
    Jan 23, 2006
    11,230
    488
    New Hampshire
    Well don't be fooled, its real polished aluminum diamond plate. :eek1: :bow:
    I bought a sheet of 24"x48" 16g gauge and it was the pefect fit. The 2 pieces I had leftover I decidied to mount on the top of the rocker panel. I'll get pics of the driver side soon.
  4. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
  5. lamberthkp
    lamberthkp SITFU Premium Member
    Jan 17, 2005
    1,468
    16
    West TN
    looks nice!
  6. k5blazin
    k5blazin 1/2 ton status
    Dec 19, 2004
    262
    Elizabethtown, PA
    Blingin!... in a good way.. Looks real sharp!
  7. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Those look sweet.
    Let me give you a little experience warning tho. I made a set of those for my burb (the alum diamond plate floor mat things). Those things get VERY slick if ANY wettness gets on them. The bottom of my boots were slick just from walking down the sidewalk. Drove to work and almost hit another rig cause my foot was sliding all over the floor trying to get to the brake pedal. Wasn't fun, so out they came.
  8. diesel4me
    Jul 24, 2003
    17,553
    939
    Massachussetts
    looks good....
    That really blings up the interior!..the only downfall is ...
    ..aluminum VS steel= battery!..
    I hope your floor was painted well before you bolted it down..keep an eye on the bolts,eventually the aluminum will turn white and salty looking around the bolts,and will erode a big hole around the bolt due to electrolisis..its best to put tarpaper or some sort of plastic between the steel and aluminum,(or paint the underside, or bedline it)..and use galvanized bolts,and replace them when any corrosion is evident..
    I have a 12' "reefer" truck body in my yard for storage..its diamond plate aluminum floor has a 2" hole where nearly every bolt held it to the channel iron floor joists!..:eek1: ...its real "slick" if it gets wet too,despite its "tread"..
    I do like the looks of diamond plate though..I have "bed rail protectors" of aluminum on my 79 C10,and I chopped an old diamond plate running board up to fit the steps on my 82 stepside--they go well with the aluminum diamond plate tool box..its a pain keeping the aluminum bright and clean here in "salt east" MA though....:crazy:
  9. DEMON44
    DEMON44 Low-Tech Redneck
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    Thats called galvanic corrosion
  10. Chevy305
    Jan 23, 2006
    11,230
    488
    New Hampshire
    My floor is totally bedlined, and I painted the wholes after I drilled them in the floor. The hardware I am using has these little rubber cushion under the washers. I also painted the little bit of the sheetmetal screws that hangs down underneath the floor.
    Hopefully that doesn't happen. :o
  11. FOR MUD
    FOR MUD 1/2 ton status Premium Member GMOTM Winner
    Apr 6, 2006
    2,801
    387
    Clayton Del
    A little to bright for me . But looks good and alot cheaper than if you just bought them .
  12. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    I'm not sure. All I see is a reflection :doah:
  13. Chevy305
    Jan 23, 2006
    11,230
    488
    New Hampshire
    I'll try to get some better photos and ones on the driverside too. My cell phone camera isn't the best.
  14. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    slippery in the rain (somewhat) and shiney in the sun, lol, i'd paint mine black
  15. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    stylin concepts sells ones a lot like that.
  16. Chevy305
    Jan 23, 2006
    11,230
    488
    New Hampshire
  17. yellowK20
    Dec 26, 2002
    7,602
    554
    Wasilla AK,
    Well it does look pretty damn sharp
  18. Chevy305
    Jan 23, 2006
    11,230
    488
    New Hampshire
    Thanks :D :waytogo:
    Thats the kind of gratification I was looking for. :D
  19. mattman4x4
    mattman4x4 1/2 ton status
    Feb 16, 2005
    186
    Salisbury MD
    I can dig the dimond plate door sil strips....they look sharp. As for the floor plates, I think glare may be a problem. You get an A+ for style though~!!:bow:
  20. Chevy305
    Jan 23, 2006
    11,230
    488
    New Hampshire
