did 250 engines have large or small flexplate
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by R72K5, Sep 30, 2003.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    around 69 model year trucks with 250, small or large ? IE 153 tooth or 168 tooth?
    what was factory/correct ?
    this block only has one starter nose bolt pattern, they are straight across design, no way to install a staggered bolt starter nose on this one,
    i would think 153 tooth
    original tranny behind it was probably 3 or 4 speed, but i have as thm200c behind it now with 153 tooth plate/
    i gotta find out anything at all, please lemme know if you know of anyone or anywhere that would know or know how to find out anything on this, im trying to find a starter for this thing
    thanks
  2. dyeager535
    26,982
    191
    I think you've discovered it...you need the staggered pattern to fit the 168 nose cone on the block IIRC, so if you can't mount a staggered nose cone, I don't see how a 168 flywheel could have been used.
