did 72's come with seatbelts?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by dysphemism, May 20, 2003.
  1. dysphemism
    dysphemism 1/2 ton status
    Oct 26, 2001
    667
    Fremont, CA
    did 72\'s come with seatbelts?
    I want to put some seatbelts in my 72, but untill I do, is it legal to not have them? The p.o. of my truck said it was exempt, but want to make sure.
  2. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Re: did 72\'s come with seatbelts?
    Yes the 72's came with seat belt's only, no shoulder belt's till I think 73'.
  3. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    76 i believe, my 75 doesn't, but my dads 77 did.
  4. IGOR
    IGOR 1/2 ton status Premium Member
    May 16, 2000
    2,303
    19
    Damascus, OR
    Correct on the '76 (I'm impressed Jeff!)
  5. rrent
    rrent 1/2 ton status
    Jun 10, 2001
    174
    Round Rock, Texas
    Its big time not legal here in Texas -- we are actually in the middle of a click-it or ticket campaign -- seat belts not buckled = a fine up to $200.00 --- ouch.
    You can bolt in almost any chevy (other brands or after market work too) seat belts. I had made some "L" shaped extenders out of 1/4" X 2" strap metal --- bolted these to the floor and belts to these. Since this I have located and installed a set of '72 truck belts. Any belts you use are going to fade in the sun if your are a topless driver.
  6. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    /forums/images/graemlins/shocked.gif /forums/images/graemlins/shocked.gif /forums/images/graemlins/shocked.gif /forums/images/graemlins/shocked.gif I'm always correct, just ask me and i'll tell ya so /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  7. JohnSPledg
    JohnSPledg 1/2 ton status
    Feb 22, 2001
    141
    Baton Rouge, La
    As far as the click it or ticket thing goes, many states exclude lap belts. There have been enough studies that show lap belts put you at more risk of serious spinal injury than no seat belt at all. I know when Louisiana first implemented its seat belt laws, vehicles factory equiped with only lap belts were exempt, unless the owner upgraded to 3 point or better restraints.
  8. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Did all 72's come with seatbelts? Mine has some mopar belts that the prevous owner obviously added.
  9. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    yes...seatbelts were manditory starting in early to mid 60's
  10. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Lap belts became mandatory for the 1968 model year.
  11. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    i was close, at least i had it in the correct decade /forums/images/graemlins/thumb.gif /forums/images/graemlins/rotfl.gif
  12. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    johnspledge is right /forums/images/graemlins/thumb.gif for louisiana. but as soon as i get my cage in i am putting 3 points. i think the road with no top on is worse than no seatbelt anyday. /forums/images/graemlins/grin.gif
    nathan
  13. bouncytruck
    bouncytruck 1/2 ton status
    Oct 11, 2001
    858
    Bothell, WA
    I bought the cheap-o lap belts from JC Whitney when I bought my truck. The previous owner didn't have seat belts or side mirrors so I couldn't drive it until I got them installed.
    There are usually a few pairs of truck seat belts on ebay at any given time.
  14. dysphemism
    Oct 26, 2001
    667
    Fremont, CA
    Ya I figured 1972 was a little late to still be exempt from the seatbelt law. It really made me think of it because I saw a huge pile-up on the way to school yesterday, probably 12 or more cars. It looked awful, jogged my memory to get some belts. If I were to get some modern belts, like what would come in a new truck, would it be hard to install them?
  15. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    I've got a set that I took out of my 72, i put 3points in...
  16. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    s-10 belts would work, etc. the threaded bolt hole needed for optional shoulder belts is above your head on both cab corners in the pickups at least
  17. blazer72
    blazer72 1/2 ton status
    Apr 13, 2000
    939
    KCMO
    trucks did not have to have seat belt till 73 cars had them starting in 67, so if you have a truck plate you may get away with not haveing the belts, but with car plate you will lose, I went though this about 4 years back when I moved my 72 from Central MO to Kansas City, The HP was cool with it but I had a few talks with a KC judge about it. I finaly change the plate from a car to truck end of story. /forums/images/graemlins/k5.gif
  18. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    im the double wall top of my blazer there is a threaded hole. i think a 3 point would screw into esy but id ont ride with the top on.
    nathan
  19. ChrisM72beast
    ChrisM72beast 1/2 ton status
    May 29, 2001
    214
    Granada Hills CA.
    It's especially not hard to install if you have a roll bar inside. All you have to do is a bit of drilling and your there. Adding a three point to your hard top is o.k....if you don't take off the top ever.
  20. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Yeah I thought so.
