Did a search but didn't find ....tap size for tie rod ends??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by shane74, Feb 28, 2003.
  1. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    Did a search but didn\'t find ....tap size for tie rod ends??
    I have access to a machine shop and cheap materials 9a buddy owes me some favors). My tie rod is shot, and I don't want to replace it with a stock one. Does anybody know the tap size for the tie rod ends? I would love to have a Rockstomper on there, but right now, I can't afford it. I can afford free labor and materials /forums/images/graemlins/thumb.gif So if anybody could help, I'd appreciate it.
  2. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    Re: Did a search but didn\'t find ....tap size for tie rod ends??
    7/8" x 18TPI
  3. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    Thanks a million!
  4. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    Just had mine threaded it is 7/8th by 18 they had to use the lathe they did not have a tap that size cost 20$ bucks plus they cut the tube to size for me.
  5. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    hey shane i have that tap if u need to borrow it.....im in puyallup though....mines a right hand thread tap and the left hand thread tap is really spendy so i did mine with rh on both ends...took longer to get it adjusted ....
  6. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    Yeah, I was wondering if that was possible. I can see where it would be kind of bear to adjust it though. Did you make your own? If so, what kind of measurements did you take? My thinking is that I would start by measuring the total length of the tie rod on my truck right now. Then by two right hand sides and lay them out that distance apart, and measure the length between them with about 2/3 of the threads inside the tube. Also, I am thining of using 1.25" or 1.375" cold rolled round stock. it'll be heavy, but it should be plenty strong! what are your thoughts?
    Yes, if my buddy doesn't have the tap, and you don't mind. I'd like to borrow yours. I'll let you know. Thanks! /forums/images/graemlins/thumb.gif
