Did a search...school me on Blazer/Jimmy floors
Discussion in 'The Garage' started by thatK30guy, Jun 7, 2006.
  1. thatK30guy
    Jan 12, 2001
    32,076
    55
    Whats the deal on the floors? Something about the hump or step and what is the year split? Whats it gonna take to run a newer tub on an older chassis? Or vice versa? Anything else other than the floor that needs attention when swapping over old to new or the other way around, such as body mounts and bushings?
  2. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    From what I remember, on old school K5s the floor is the same height front to back.... on newer ones (like my 85) there is a "step" in the tub (about 6-7") just before the rear seat.
    I would imagine swapping bodies to different frames would require fabbing some new/different body mounts... at least... not 100% sure what other issues might be involved. Whats the project? Might be easier to go truggy. ;) :thumb:
    j
  3. tRustyK5
    Jul 23, 2000
    36,170
    1,377
    E-town baby!
    '73 to '77 don't have the footwell behind the front seats. The frame also rises up farther forward than the '78-91's. Last difference is the body mounts behind the front seats are inboard on a crossmember. The later models have outboard mounts.
    Old body on a new frame is doable if you build a crossmember for those body mounts. New body on an older frame is a bunch tougher...you'd have to section part of the floor (behind the front seats)for it to fit over the frame, and add outboard body mounts.
    Rene
  4. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    body mounts have another year change in them.... It changes at '81 with a new style front clip....
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    Sounds like too much hassle to put a new on old. :( Gonna be tough to find literally a rust-free tub in those early 70's years.
    I didn't notice the floor being flat when I was blowing the inside out when I got it. Now you mention it, I will check it out tomorrow when I get home from work. :wink1:
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    While I was thinking of it, wouldn't a body lift help clear the frame/floor to raise it high enough that sectioning the floor wouldn't be necessary? But still have to add the outboard mounts.
  7. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    The floor isn't actually flat, but right behind the drivers seats the floor raises up and then straight back to the gate on the 73-77, on the 78-91 the floor doesn't raise up for about a foot or so after the drivers seats then straight to the gate.
  8. thatK30guy
    Jan 12, 2001
    32,076
    55
    Gonna let this thread ride a little bit and see if anyone can post up pictures of both types of floors so we can see/view them for better ideas.
  9. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    If by tomorrow night no one has taken a pic of the 78-91 version i will take a pic and post it for ya.
  10. thatK30guy
    Jan 12, 2001
    32,076
    55
    Looking forward to it. :waytogo:
  11. Greg72
    Mar 5, 2001
    15,682
    1,392
    642 Days to BB2018
    Wes,
    Here's a shot of the early style (taken of a '77K5):
  12. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I stuck a 77 tub on a 83 frame . The front mounts are the same location , the rear mounts are the same location . Its only the middle mounts that are different .
    If you took the middle mounts of the side of the frame on a newer frame , it would work very well .
    In my case its a truggy , so my slider kickers are going to the frame to shore up the middle of the tub .
    In my case I also raised the rear of the body a bit with lift bushings , so that my 77 tub can fit on the 83 middle frame mounts . Seems there is a rail on the 77 that I could of cut off to make it sit flat on the frame ( 77 has no rocker boxes ) , but I like it higher in the rear for use of regular springs .
  13. thatK30guy
    Jan 12, 2001
    32,076
    55
    That quote brings up another interesting question: Are the rears of the pre-78's lower than the newer trucks?
    My '74 rides on 4" Rancho front springs but only has 2.5" blocks in the rear.
  14. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    That I am not sure about . I think there is a frame dimension page I saw a while back . Will find it and link it for ya .
  15. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
