Did I ask the wrong question?
Discussion in '1982-Present GM Diesel' started by grumpy, Jun 4, 2001.
  1. grumpy
    grumpy 1/2 ton status
    Jan 7, 2001
    353
    San Diego, CA
    I did not get any replies so I thought maybe I was not asking the right questions. I wanted to know if there were any items beside the motor I should take. External pumps, fuel lines, gas tank etc.
    David
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    OK, OK, lets see..............You'll need all the wiring and the relay for the glow plug controller. You'll need a dual battery setup. There's also an issue with the brake booster- I'm not sure exactly what needs to be done, but I assume it has something to do with the fact that a diesel doesn't produce it's own vacuum and needs a vacuum pump(which runs off the cam). It would also be wise to take the exhaust off the donor vehicle and see if you can use any of it..........
    I would think that the fuel lines should be replaced and fuel tank(s) thoroughly cleaned.
    I can't think of anythinig more off the top of my head..............maybe some others can offer you some more suggestions.
    <font color=red>PHOTO ALBUM-</font color=red> <A target="_blank" HREF=http://albums.photopoint.com/j/AlbumList?u=1289798>http://albums.photopoint.com/j/AlbumList?u=1289798</A>.......<font color=blue>TRUCK & HIKING PICS</font color=blue>
  3. Steve_87K5
    Steve_87K5 1/2 ton status
    May 26, 2000
    521
    central NC
    Did you get the hydroboost? The A/C bracket is also a diesel item, at least it
    was on my '84.n There are some diesel relays on the drivers side
    fender panel too.
    SteveB
