Did I Bend the Frame? *PICS*
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Just4Fun, May 4, 2007.
  1. Just4Fun
    Just4Fun Registered Member
    Sep 2, 2005
    28
    Shreveport, LA
    Obviously I need new bushings here but It doesn't look like thats gonna bring it back all the way. If this is in fact bent, How do I bend it back?
    If it is bent, and I get new bushings... Supposing I can still line everything back up after I pop it apart. Do you think it'll still ride ok?
    The right side looks perfect but this left side is obviously bent about an inch or so towards the inside of the frame.
  2. justiz00
    justiz00 Registered Member
    Dec 11, 2006
    83
    Central Texas
    THe right side of my frame is like that in the same spot. Its not a daily driver so im not too worried. Not going to change anything.
  3. W7NB
    W7NB 1/2 ton status
    Nov 9, 2006
    716
    Springtucky, OR
    Looks more like you need busihings and new shackles. Did you shear the pins off the bolts that hold the springs in the pads when you hit? Looks like the springs are cockeyed on the spring pads as well, but not sure by the pics.
  4. chevyin
    chevyin 1/2 ton status
    Sep 14, 2005
    1,324
    Pismo Bch CA
    Humm...
    That should buff right out:haha: :haha: :haha:
    Sorry I have nothing more constructive to add.
    PS. PAD
  5. chiefheaphy
    chiefheaphy 1/2 ton status
    Mar 13, 2007
    632
    East MASS
    Do exactly what you did to cause that but do it the opposite way. Problem solved.
    Seriously though...looks pretty mangled. I'd say BFH but then again my truck is torn dwn to two bare frame rails and some x-members. When theres stuff in the way its a whole nother strory.
    Id say unbolt the front end and get it out of the way. Remove that hanger by grinding down the 4 rivets and either slam the sh** out of the frame or try using a bottle jack sideways only problem is you dont want to bend the other frame rail out.
  6. chiefheaphy
    Mar 13, 2007
    632
    East MASS
    did the front get hit?
  7. Just4Fun
    Sep 2, 2005
    28
    Shreveport, LA
    The front left tire fell off in a deep deep rut and over-flexed the suspension.
  8. Just4Fun
    Sep 2, 2005
    28
    Shreveport, LA
    I guess I'll just replace the bushings and hammer down..
  9. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    frame looks twisted to me,,,good luck
  10. realsquash
    realsquash 1/2 ton status
    Jul 12, 2000
    778
    SE WI
    Good luck replacing those bushings. You'll have to bend the spring if it's not permanently tweaked to get the bolt through. You would be wise to find some way to bend the frame back if at all possible.
    Andy
  11. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    this is a stretch..
    but it *ALmost* seems as though the centering pin has sheered and the axel has moved..
    how is your steering feel?
    also, bushings then if that does not do it, get a highlift in there and tweak it back.. or take it to a body shop and have some floor anchored frame pulls done *cheap* or have it done on a frame rack *more $$"
  12. Jishory
    Jishory 1/2 ton status
    Jan 8, 2002
    1,367
    Palmdale, CA
    my frame is bent like that, got in an accident before i got it, makes it fun getting leaf springs to line up
  13. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    Frame does look tweaked. You might want to reall consider the shop suggestion. The more you BFH it the weaker it will get and still won't be as straight as a shop.
    Use a level and a 90* angle to see how far out it is and then make a decision though.;)
  14. dhjunkie
    dhjunkie Registered Member
    Apr 24, 2007
    26
    Los Angeles,Commiefornia
    Yep. She looks to be twisted. Snap another picture capturing the cab body body mount with the shackle all together so that I can take a better look and give a more accurate answer. Any body shop with frame equipment should be able to straighten it up for around 5 hours of labor.
