Did I F@#%K UP OR WHAT ????
Discussion in 'The Garage' started by mollyman, Dec 18, 2006.
  1. mollyman
    mollyman 1/2 ton status
    Aug 18, 2006
    280
    west virginia
    I have a quick question for anybody out there. I've got an 81 k10 sub and this weekend I was taking out the rear leaf springs (huge pain in the ass). I pulled the axle out of the way. But instead of taking the drum brake apart to unhook the parking break cable I just ground off the 2 rivets holding the braket that holds the cable hard line on both sides. Then after I did that I noticed that the rivets also go through the spring hanger and help hold it to the frame!!!! Did I f$%k up or what??? Because I was going to ditch the parking brake because I'm puting in a 14blt. Do I need to weld the spring hanger along the edge where the 2 rivets used to be or drill them out and blot them or is it no big deal. Any help would be great.
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Just install some grade 8 bolts in those locations.
  3. makovai
    makovai 1/2 ton status
    Jun 6, 2006
    854
    oregon city
    When you do a shackle flip you grind off the rivets and replace them with bolts, I dont see why that would be any different. Just drill them out and replace them with grade 8 bolts and move on. Thats just my opinion.
  4. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    if you ground the entire head of the rivet off you should be able to use a hammer and punch and push out the rest.
  5. AZ79K5Project
    AZ79K5Project 1/2 ton status
    Jan 15, 2006
    2,082
    Arizona
    Your part way to the shackle flip. Why not order it, grind the rest off and install it and call it "planned".
    x5 or 6 on the grade 8 though.
  6. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    because the e brake cables dont run through the rear hangers. :doah: :haha:
  7. AZ79K5Project
    Jan 15, 2006
    2,082
    Arizona
    That's the problem with my flip, I put it on the front...:haha::haha::haha:
    That's what I get for talking to my 5 y.o while reading posts.:doah: Well hell then, cut it all off then for practice.
