Did I get a good deal???
Discussion in 'The Garage' started by slider79blazer, Apr 21, 2004.
  1. slider79blazer
    slider79blazer 1/2 ton status
    Mar 23, 2001
    164
    littleton,co.
    I bought a 1980 chevy 1 ton pickup for $300. it has a corp.14 bolt rear axle, a corp. 10 bolt front axle w/4:10 gears. Also the driveshafts and a married 465 4/speed tranny and 205 transfer case.No engine was with it. I'm putting it all on my 1979 blazer. And yes it is all in good working condition. Do you think this is a good deal or was it to much? Thanks for the input. /forums/images/graemlins/thinking.gif
  2. ratzila
    ratzila 1/2 ton status
    Aug 9, 2003
    691
    Mobile,Al
    For $300 you did get a good deal to swap into the k5, but a 1 ton should have had a dana 60 front. Did someone already swapped out the front end?
  3. slider79blazer
    Mar 23, 2001
    164
    littleton,co.
    I don't think they were switched as far as I know it is all original.
  4. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif
  5. cybrfire
    Dec 15, 2002
    15,142
    568
    Iowa
    sounds like a good deal. Even if the D60 has been pulled from the front.
  6. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Good deal /forums/images/graemlins/thumb.gif
  7. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    The Dana 60 has 10 front cover bolts. Does your axle have king pins or ball jointed steering knuckles? If there are caps on top of the knuckle with 4 bolts it's a Dana 60, if there's a ball joint it's a 3/4 ton front. Either way, good deal /forums/images/graemlins/waytogo.gif
  8. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    quicker way to tell if you know know what trucknutz means is simply, look under the front of the truck, if you see 3 u bolts and 2 studs holding the front axle, do a little dance.
  9. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yeah being an 80 it could still be 3/4 ton or 1 ton either one thanks to having a 205 in it.
    i bet ya its actually a K20 lol
    but good deal anyways
    also all GM setups asre married anyways, no unmarried setups by gm for a super long time way before any 70s or 80s, if at all
    good luck
  10. slider79blazer
    Mar 23, 2001
    164
    littleton,co.
    thanks everyone for the help. I'm going to look into the front axle some more because a buddy at work says the cover doesn't look like a dana. He says he's never seen this shape of axle before.
