Did I hit the motherload?
Discussion in 'The Garage' started by oldassjeep, Sep 16, 2005.
  1. oldassjeep
    oldassjeep Registered Member
    Oct 21, 2004
    84
    Burnet TX
    OK I found this '86 Chevy 1 ton single axle. I know it has the 14 bolt (figured it out all by my lonesome) :rolleyes: But I have a few questions about the front axle and the transfer case. Are they good to have? Also can anyone identify the winch on the bumper. Thanks
  2. redneckdude
    redneckdude 1/2 ton status
    Feb 21, 2004
    578
    Augusta, GA
    That front axle is no good...id happily take it off your hands and even put 500$ in ur wallet.
  3. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    i cant see the pics but its most likely a d-60, 205 (maybe 208?) 400 if its auto.
  4. BigCountryx
    BigCountryx 1/2 ton status
    Feb 19, 2005
    519
    Gonzales, LA
    D60 it is as well as having what I think is a Warn 8274 hanging on the front Eureka.
    How much? If you make an offer don't appear to be jizzing in your pants, unless he allready knows the value of what he's got :D
  5. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    Thats what I see too. Not sure of the transfer case though...
  6. sweetk30
    Nov 1, 2004
    25,542
    539
    horseheads , ny 14845
    its all good man grab it.:p:
  7. mrk5
    Apr 20, 2004
    12,333
    1,043
    Northern Colorado
    I would guess it's a 205, I know they did slipyoke 205s bu I thought there were only in the 3/4 and 1tons.
    The only reason I'm saying 205 is because my 208 fill and drain look different. They are big hex heads that are really short. Plus that tcase just doesn't seem to look like mine.
    I can't see the tcase shift linkage. If it is 2 pistons actuated by a lever with center pivot then it should be a 205. If it is linkage rods attached to levers, then it is probably a 208.
    IIRC a 208 shift pattern is 2H-4H-N-4L reading front to rear. I know the 205 is different.
  8. sweetk30
    Nov 1, 2004
    25,542
    539
    your pics = dana 60 front / 205 slip yoke / warn 8274 style winch. also with further looking the crossmember is newer style. and this will mostlikly have round6 bolt tcase mount setup not the fig 8 setup.
  9. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Dana 60 Front :waytogo:
    Slip Yoke NP 205 :waytogo:
    Winch and bumper...Not sure :dunno:
  10. Mammoth2
    Mammoth2 Registered Member
    Aug 4, 2002
    42
    TX
    cant see the pics either......i must be a loser :doah:
  11. blazerpro79
    blazerpro79 1/2 ton status
    Jan 4, 2005
    528
    Simi Valley, CA
    haha i always jizz myself at the sight of a d60 :haha:
  12. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Now there is a visual I could've done without...... :D
  13. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    that front axle is trash. it only has 3 u bolts, how do you expect it to stay under a truck?
  14. blazerpro79
    Jan 4, 2005
    528
    Simi Valley, CA
    maybe by adding another u-bolt.i wouldnt say its trash because it isnt mounted right.
  15. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    where are you going to put another ubolt? whatever idiot cobbled that thing together didnt leave enough room for a second u bolt on that side. just for safetys sake, i'll trade you a complete set of 4.10 3/4 ton axles, complete with 4 u bolts on each axle. that thing is a death trap, and i'd hate to see someone get hurt when i could do something about it. :haha:
  16. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    in a word, "yes". Except the slip yoke 205... which is sorta worthless unless you want to take parts from it to complete a Lomax 3:1 205...
    j
  17. fourwheelerjeff
    fourwheelerjeff 1/2 ton status Staff Member Moderator
    Nov 16, 2001
    3,419
    6
    meadow, tx; in the boonies
    northwest fab has a kit to eliminate the slip yoke on the 205 :wink1:
  18. bigjbear
    Feb 18, 2000
    13,971
    451
    Marietta GA
    No guessing. It is a D60 front. Look at the kingpin. I never trust the 3 U-bolt/2stud thing because Dodge did it on their D44s and they fit under a Chevy easy enough. The case is an NP205. See the idler cover w/ the 3 bolts holding it on? The winch is an older model 8274. That was easy to tell but you know was not built in the last 7 years because of the round freespool handle & plug in the front. Good find, buy it now if the price is right.
  19. W200
    W200 Newbie
    Sep 17, 2005
    3
    San Jose CA
    nice try man!!!
  20. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    The front is a 60 and I would say an new one which means it has the axles that are not necked" down. The transfercase is a 205 and you can tell that by the plate with the 3 bolts. mine was a slip yoke when I bought it, I converted it to a fixed yoke....................................................
