Did search. ?'s on 12 bolt strength *Edited*
Discussion in 'The Garage' started by y5mgisi, Oct 10, 2003.
  1. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    Did search. ?\'s on 12 bolt strength *Edited*
    Im sure that it has been covered on here but i serched didnt find any thing. SO what i need to know is this: Will a stock rear(unlocked) 12 bolt handle the streess of 300hp and 35's? If it will handle it being floored from a dead stop**(As in power brakeing, or dragracing or summthin. Not revvinit up and dropin it in gear........)**, without breaking i think i should be ok. What do you all think? /forums/images/graemlins/ears.gif
    P.S. geeze guys calmdown i didnt mean to start any thing with this... Is it that time of the month again or somthing? /forums/images/graemlins/eek.gif
  2. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    Re: Did search. ?\'s on 12 bolt strength
    Get a 14 Bolt FF
  3. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Get a 14 Bolt FF
    Good answer numbnutts............... /forums/images/graemlins/deal.gif /forums/images/graemlins/deal.gif
    So how do you drive?
    How extreme are ya?
    Answer those questions and if the answers are anything other than "Like Granpa" and "The mall scares me," then you need to upgrade.........
  4. K5 NUTT
    K5 NUTT 1/2 ton status
    1,611
    Grand Junction Colorado
    Neutral drops are hard on any drivetrain setups....but marv...rob and i all run 12 bolts from moab to az trails witha full detroit and zero breaks so far...but skinny pedal has to be used wisely as to much will break shizzle...
    DW
  5. mudjunkie 82
    Dec 27, 2002
    11,449
    Cleveland Ohio
    who are you refering to as numbnuts ?
  6. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    Read the "Reply to" box...........
    We are all here to learn various things. Throwing some random comment out that doesn't answer someone's questions doesn't help one bit. Maybe you should find out what the guy has planned first before making off the cuff comments. Educate the masses............. /forums/images/graemlins/thumb.gif
  7. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    oh and dont reply to tech messages with non-tech crap, right BRB???
  8. mudjunkie 82
    Dec 27, 2002
    11,449
    Cleveland Ohio
    Well as an off the cuff comment you are wrong,he stated what he wants to do with it did he not?If you think that get a 14 bolt ff did not answer his question in a short simple sentence then I don't know what to tell you. As far as name calling goes-Blow Me!!!!
  9. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    Oops, my bad. Missed the last part. /forums/images/graemlins/shocked.gif
    But it's still a BS answer. Maybe you should substantiate your answer, inquiring minds what to know.......................
  10. Confedneck
    Nov 1, 2002
    5,236
    yeah, us inquiring minds even WANT to know.. /forums/images/graemlins/grin.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/grin.gif
  11. chillywilly
    chillywilly Registered Member
    May 26, 2002
    70
    northern maine
    Ask one simple question...get a pissin match lol!! /forums/images/graemlins/shocked.gifWell dont know how your gonna use your truck but Ive run my 12b for years with alot of 35s. Had real good luck ,no rock climbing way up north but lots a mud and trails!! /forums/images/graemlins/truck.gif
  12. mudjunkie 82
    Dec 27, 2002
    11,449
    Cleveland Ohio
    I only Recommended a 14 bolt because he sounds like he plans to romp on it.
  13. the cork
    the cork 1/2 ton status
    Apr 20, 2003
    128
    mid west,
    i never broke mine doing that with big blocks and 35s,
    your probably going to break front axle ujoints before
    the 12 bolt breaks,
  14. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,139
    14
    Bangor,Pa
    i second the get a 14 bolt comment,but thats me.i have broken 2 12 bolts so i am a little biased against them.one was locked and one was not.never broke a drive shaft but for some reason,the center section likes to come apart on me.go figure.i broke one just spinning a brodie in gravel.no problem with the 14 bolt as of yet with 2 years on it.and i like to drop the hammer on occasion./forums/images/graemlins/eek.gifprobably why the 12 bolts never survived. /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/crazy.gif
  15. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    the 12 bolt breaks,
    I doubt that. You'd probably trash the 12 bolt in 2wd before breaking the front axle the small amount that your rig is in 4wd.
  16. y5mgisi
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    wow...... Well thanks for all the replys. Mabey it makes more sence now. /forums/images/graemlins/eek.gif
  17. mudjunkie 82
    Dec 27, 2002
    11,449
    Cleveland Ohio
    Mitch,14 bolts are cheap to buy,way stronger than a 12 bolt,lockers are fairly cheap as are the rest of the parts.you can convert to disk brakes real easy and later on if you decide to go with bigger tires you wont have to worry about the strengh of it.also I think that the 14's driveshaft yokes are bigger so you can run a lot heavier driveshaft..........
  18. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    Re: Did search. ?\'s on 12 bolt strength *Edited*
    I think it'll hold up. It's usually a tire spinning madly then getting traction that kills them in my experience. I have an old 10 bolt shaft with twisted splines that I messed up when I blew my first set of spider gears.
    I have LockRights in my 10 bolts now and I think the weak link is going to be the shafts. I mean, you can feel the shafts in the back "wind up" and then the tire lets loose. I used to worry about the carrier but I think it's going to be the shafts.
    Of course, the wicked wheelhop I get now might blow universals. Hold the stupid pedal to the floor and it bounces like a bucking bronco.
