DID SEARCH,WILL DRIVESHAFT FROM A SHORTBED...
Discussion in 'The Garage' started by boggerless, Apr 5, 2004.
  1. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    fit on a k5 with a six inch lift??? i know the back of the rear fenders are longer,but is the driveshaft??will it work or not?i need mine lengthened about three inches but if its long enough that would be easier obviously. thanks /forums/images/graemlins/grin.gif /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    A shortbed driveshaft is going to be way too long.
  3. boggerless
    May 26, 2003
    22,728
    96
    thats what i was wondering.mine is so short that it falls out in my yard but it doesn't on the road.i guess i'll get it done. thanks /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  4. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    shortening a drive shaft is cheaper than getting it lengthened. you can't just add more tube to the exsisting tube, you must replace the entire tube, while shorting it you just machine it down to the lenghth you need.
    what tranny you running? i have a 465/205 driveshaft from a shortbed that you could try out on it. what length do you need?
  5. 85scottsdale
    85scottsdale 1/2 ton status
    Dec 22, 2003
    283
    Lewisville, NC
    My pickup has a 117.5" wheel-base, so its longer than a k5 and probably too much longer.
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Yep, I said that in my first post. /forums/images/graemlins/thumb.gif
    What was said above about, "A shaft that is too long can be shortened but a shaft that is too short needs a new tube" is absoulutely correct. I was on a budget when I made my rear shaft, so I went with a used 3/4 ton longbox shaft from an automatic truck and had to have it shortened and balanced.
  7. boggerless
    May 26, 2003
    22,728
    96
    i have a 400 trans and a 203 t case. i was hoping to get a drop in part. i want to have it done for june 5th. what shaft do you guys recomend to shorten, the short bed or a different one? thanks daryl /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  8. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    a shortbed wouldn't have to shorten as much. you also need a slip in the shaft right?
  9. boggerless
    May 26, 2003
    22,728
    96
    yea, mines been shot for years(fill it tight with grease). /forums/images/graemlins/grin.gif /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
