did the 73-91 generation come with a manual tranny ?
Discussion in 'The Garage' started by jfman, Mar 20, 2006.
  1. jfman
    jfman Registered Member
    Mar 19, 2006
    19
    Atl
    Hey guyz, I'm new to the site and I am thinkering wioth the idea of getting a k5 Blazer.
    I want a manual tranny K5 but I have yet to locate one.
    Did they even ever made them ?
  2. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
  3. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    i bought a 1985 blazer.. with a manual.. smc465 and a hydraulic clutch....
    so that would be a good thing to look for...
    or you can always swap one in.. not hard.. but on a daily driver a weekend will be pushing it if you never did it before..... but hydraulic in the weekend is more duable than a mechanical....
  4. jfman
    Mar 19, 2006
    19
    Atl
    So they came with 4 speed manual trannies...
    Can you swap in a t56 or a better manual tranny ?
  5. yoshisv
    yoshisv 1/2 ton status
    Feb 19, 2006
    266
    Hartsville, Tennessee
    They did make them, And i recently sold a 89 k5 that had a factory 4 spd for $800 (bad motor)
  6. yoshisv
    Feb 19, 2006
    266
    I dont no if a t56 will bolt up to a transfercase, Though with enough money anything is possible!
  7. RootBreaker
    Nov 29, 2001
    5,117
    173
    hmm at least you said you were new so I will be nice :haha:
    you wont find a much better tranny than the smc465.. plentiful around and very strong... VERY strong... and yes 4 speed.... granny, first, second, third...
    however you can get a nv4500 (best year was 1994 I think with a low granny gear) and will give you overdrive.....
    problem with many smc465 is the shift ratio....
    1st 6.55
    2nd 3.58
    3rd 1.7
    4th 1
    the only sucky parts is that when you shift out of 2nd into 3rd.. 3rd revs REALLY FAR due to the big difference in the ratio....
    nv4500 is what I want to do someday....
    1st 5.61
    2nd 3.04
    3rd 1.67
    4th 1
    5th O/D 0.74
  8. yoshisv
    Feb 19, 2006
    266
    I have the sm465 in my 89, But was wondering what the difference is in strength compared to the nv4500?
  9. 1985_K5_Silverado
    Dec 21, 2005
    984
    Corn Country
  10. jfman
    Mar 19, 2006
    19
    Atl
    A bit far :D Is it even a 4x4 ?
    I found plenty of 3-4k 4x4 blazer but all are auto's
  11. jfman
    Mar 19, 2006
    19
    Atl
    What did the nv4500 come out of ?
  12. 1985_K5_Silverado
    Dec 21, 2005
    984
    Corn Country
    Hmm, that is a ways away, now that I see your location. Yes, that'd be a 4x4.
  13. yoshisv
    Feb 19, 2006
    266
    I believe they came out in the 89 and up gm trucks, But not 100% sure
  14. RootBreaker
    Nov 29, 2001
    5,117
    173
    yeah but the earlier years came with the better (lower) granny gear.. neither can match the smc465.. but still I would sacrifice some to get the OD!!!! :bow:
  15. jfman
    Mar 19, 2006
    19
    Atl
    Will the smc465 TC bolt right onto the NV4500 ?
    Same location ? (I'm concerned with having to have the driving shafts redone)
  16. RootBreaker
    Nov 29, 2001
    5,117
    173
    err huh?
    they are both trannies... so they wont bolt onto each other.... did you mean.. will they both bolt onto the motor?
  17. jfman
    Mar 19, 2006
    19
    Atl
    TC = transfer case
    Will the SMC465 TC bolt onto the NV4500 tranny ?
  18. noahrob
    noahrob 1/2 ton status Author
    Nov 26, 2005
    1,878
    Santa Barbara
    SM465 = Tranny
    NV4500 = Tranny
    NP205, 203, 241 etc...= Transfer Case
    Unless I am mistaken (very possible) the SM 465 and NV4500 are interchangable in so far as they will both bolt to the block usign the same bolt pattern.
    For what its worth, I did the swap from a TH400 to a SM465(lever, not hydro) and even though I am a hack, it wasn't that hard, although it took more than 2days, more like 4.
  19. jfman
    Mar 19, 2006
    19
    Atl
    Those transfer cases bolt onto the NV4500 ? correct ?
  20. noahrob
    Nov 26, 2005
    1,878
    Santa Barbara
    Need an adapter, but with an adapter, yes...
