Did the homemade shackle flip today. PICS
Discussion in 'The Garage' started by MOABDADC22, Sep 9, 2003.
  1. MOABDADC22
    MOABDADC22 1/2 ton status
    Jul 24, 2001
    1,348
    Cheyenne, Wy
    Well, I thought I had to work today, but then I realized I am an idiot. Soooooo I had a few extra hours to kill. Good thing too, because it took about two hours per side with a cut off wheel. I only used two 1/16" X 3" wheels in the process.
    I got a few pointers from you guys here and decided to leave the hangars on the K5. Here are a few pics.
    Before: [​IMG]
    Rear wheel well before: [​IMG]
    Hole I cut (I did square up the hole after this pic) [​IMG]
    After: [​IMG]
    Exactly 4" of lift: [​IMG]
  2. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    /forums/images/graemlins/thumb.gif look awesome!!/forums/images/graemlins/thumb.gif
  3. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    I will apologize now if this seems to be hijacking!! I'd like to say that what you did looks really great!!
    Other than the obvious cost benefit, does anyone know of any pros/cons to this versus the standard shackle reversal kit? Specifically, has anyone ever had one of these homemade kits fail under usage? Thanks.
  4. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    looking good /forums/images/graemlins/thumb.gif ill be doing the same thing soon /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  5. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    There is risk when doing this, but I have done it and it has worked great with no problems. In theory it weakens the hanger, but it depends how much you cut (I cut only as much as needed) and the hanger is made from thick metal. I think there is a write up here at the site Here
    Don't forget guys (and gals) that there is lots of useful info off the main page of this site /forums/images/graemlins/thumb.gif Tech Articles
  6. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    i did this to mine also....like 4 years ago....when i installed greasable spring bushings a few months ago i noticed the hangars are no longer strait /forums/images/graemlins/1zhelp.gif....but ive wheeled mine hard,and towed a camping trailer and a car trailer with it several times /forums/images/graemlins/thinking.gif..im sure its been over loaded a few times.....i would venture to say if you dont tow much than they should be fine /forums/images/graemlins/thumb.gif
  7. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    put a truss or 2 on it pm rene(trustyk5) he can give you pics of his that will strengthen it back up /forums/images/graemlins/thumb.gif
  8. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Had mine like that for almost two years, and have wheeled the piss out of it with no ill effects.
    John
  9. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    It _might_ bend. I've seen them bend on rusty trucks in the great white north when you cut a hole in them. However, that looks like pretty virgin metal. That support piece on the backside is very much needed. 2wds didn't get that from what I can tell.
    Some people run a piece of metal between the hangers but my spare tire is located there.
    This is what I did:
    http://www.wrath.com/projects/vehicles/images/84k10/liftandaxles/rightrearshackle.JPG
    It's a front hanger off my 77C20 HD 2wd. It's also bolted to the Reese hitch.
  10. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    This is what I did:
    That's exactly what I did as well.
  11. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    I gussetted mine. Pretty simple to do...
    Rene
  12. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Thats exactly how I first shackle flipped my Blazer. Still have the holes under my brackets /forums/images/graemlins/crazy.gif
    Rene has it right, its smart to brace the hanger afterward as he has done to prevent shifting of the outer edge.
  13. BadBowtie1
    BadBowtie1 1/2 ton status
    Nov 5, 2002
    456
    Mill City,OR
    About how much lift did it give you?
  14. wrathORC
    Apr 27, 2002
    908
    Hancock, MI
    My elite math skills says 40 1/4" - 36" = 4 1/4".
  15. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    The axle is mounted at 26" on a 52" spring (exactly the mid point) and you moved one end of the spring down 8" (a 4" shackle center to center of the bolt holes rotated 180 degrees). The most you could get mathematically with an 8" change at one end of the spring would be 4" at the center of the spring without lengthening the shackle. But, since the spring is traveling on the arc of the front eye (the one not relocated), and your measuring lift relative to the ground, your resulting vehicle lift will decrease as the spring rotates past parallel with the ground. So you can only lose lift from your mathmatical maximum, not gain any more. The good thing is that the stock spring is a little above parallel to the ground in the back before the flip and a little below parallel after the flip so your going to get as close to the maximum of 4" as possible, considering the geometry. Since you have to shim the pinion back down, you gain back that missing 1/8" right there. As for vehicle overall lift, if you were sitting low with a set of true 4" blocks (not 3 1/2" rancho tapered lift blocks) then you will sit low with a 4" flip. If you have the Rancho ones then you'll gain a bit and might be happier! /forums/images/graemlins/thumb.gif
  16. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    How did your driveline angles end up? I am thinking of doing a cheap 4" lift on my truck with stock 52" springs on the front (move front spring perches) and a shackle flip on the rear...
  17. wrathORC
    Apr 27, 2002
    908
    Hancock, MI
  18. wrathORC
    Apr 27, 2002
    908
    Hancock, MI
    You're entirely correct in your reasoning.
    However, you forget that half ton trucks have the obnoxiously long front hangers. They did this so they could maintain ride height by changing front hangers on 3/4 ton and 1 ton trucks so they could run different axle tube diameters and spring pack thicknesses.
    My springs, after the shackle flip, are almost level (line going through the spring eye centers). The rear spring eye sits 1" further from the bed bottom than the front spring eye. So, using your reasoning it is entirely possible to gain more than 4".
    Next is shackle usage. Some people move their rear hanger to better control the spring-bent-backwards syndrome. Some people move it forward so it is nearly impossible to bend it backwards. Some people leave it neutral (maximum lift). Some people move it rearwards to make it easier for maximum wheelwell stuffing.
  19. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I think you and I agree for the most part, except on acheiving more lift from the flip alone. I just hosted a rather lengthy discussion on this topic recently so I happen to have some of the diagrams left over. The spring is a fixed length from eye to eye following the leaf so regardless of hanger location or shackle angle you can calculate your maximums. Hanger location and shackle angle can however reduce from the maximum. The only way to gain more lift in a shackle flip configuration than half of the rear eyes total relocation is to move your axle to the outside (or rear in this case) of the centerline of the spring. Take this image as an example:
    Distance A and distance B are both augmented by 4 units yet the effective change on the Y axis dramaticly less on A. The perimeter shown as Z could reperesent your shackles full rotation. Deviating from 90 degrees perpendicular to the spring would result in less change to the Y axis, never more. As long as the axle is dead center of the spring, you have a fixed maxiumum of half the outer edge change from a shackle flip alone.
    Shackle angle is a whole different discussion - I cut and pasted this from my tech for all those interested:
    Technical Title:Customizing Your Shackle Angle
    Category: Suspension
    Quick Eplaination:
    When swapping on longer springs or moving spring hangers it is important to calculate the desired lift into the shakcle angle.
    Detailed Description:
    The loaded length of a spring and small tollereances here and there in the real world can add up to a loss. Take a look at the top right image, each grid line equals 1". Value X equals the distance from the shackle hanger mount, value Y equals the resulting height. The blue curve reperesents the 8" shackle arc of travel. If we start with X as 8", the the shackle would sit horizontal or zero degrees. Take 1" from X at this point and the 8" shackle arc of travel will pull Y to +4" (height) and a near 30 degrees of shackle angle as shown in RED above. Taking yet another inch from X yeilds half of the initial result as shown in purple due to the shackle arc.
    Final Result:
    Springs are generally measured from eye to eye under load. But changing the load could in effect result in a loss of arch and effectively lengthen the spring. You can see from the chart above how 1" gain could take you from a 30 degree shackle angle to zero and a loss of 4" in height. I would suggest measuring the spring eye to eye under the amount of weight you intend to put on it, then measure the true length of the spring, along the spring (not horitontally eye to eye). Set your shackle angle to be 1" less then Horizontal with the springs TRUE flattened length so as never to over extend, and adjust the rear hanger height to give you your desired lift at the loaded length and resulting angle.
  20. wrathORC
    Apr 27, 2002
    908
    Hancock, MI
    OK, I admit, I haven't read the whole thing yet. I will, I promise.
    But from what I see, you have forgotten that the centerline of the axleshaft is several inches away from the leaf with eyes on it. This is especially true in a case where the front of the spring is pointed down from the factory. The centerline of the axleshaft is actually behind the point where the spring pack bolt goes through the top leaf.
    When you keep the front spring eye fixed and rotate the back down the centerline of the axle actually is directly underneath the center of the spring (the spring pack bolt hole).
    I mean, when I think about it I remember the fact that my front spring eye was 7" lower than my rear spring eye and it is easy for me to imagine. Because not only am I moving the rear spring eye 8" down but I am also moving my axle directly under the spring. Add to that shackle position and it seems completely possible for a person to gain 4.25".
